Hi All,
I just attempted to upgrade my existing R3.9 installation on Ubuntu 9.10 to R4. I did:
sudo ./makeall install clean per the readme file (actually the readme doesn't mention sudo but a couple steps in i realized i needed it). Lots of scary things flashed by, and i caught various warnings going by. It then stopped with "There were some errors." So I tried an rtrace job that I know runs on 3.9, and it still runs. But when I add the -n option (-n 2 or -n 4, for example), it crashes with a fatal error: command line error at -n. (It's a four core machine with 4gb ram)
To the extent that it remained on the screen, the output from my installation follows. Any help would be greatly appreciated!
Cramer
Cramer Silkworth
212 219 2255 | [email protected]
Transsolar Inc. | 134 Spring Street Suite 601 | New York, NY 10012
Transsolar Climate Engineering
Technical consulting for energy efficiency and environmental quality in
buildings.
New York - Stuttgart - Munich
usr/include/X11 -DNOSTEREO -c -o pcond2.o pcond2.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o pcond3.o pcond3.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o pcond4.o pcond4.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o pcond pcond.o pcond2.o pcond3.o pcond4.o warp3d.o \
-lrtrad -lm
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o pcwarp.o pcwarp.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o pcwarp pcwarp.o warp3d.o -lrtrad -lm
make: Target `install' not remade because of errors.
rm -f pfilt ttyimage psign ra_tiff normtiff pvalue pcompos protate ra_hexbit ra_bmp ra_t8 ra_t16 pcomb pinterp pflip ra_ppm ximage xshowtrace ra_rgbe ra_pict ra_ps pextrem ra_gif ra_xyze macbethcal pcond pcwarp *.o core x11findwind.c
cd tiff; make distclean
make[1]: Entering directory `/home/nyclinux/Desktop/ray/src/px/tiff'
make[1]: *** No rule to make target `distclean'.
make[1]: Leaving directory `/home/nyclinux/Desktop/ray/src/px/tiff'
make: *** [clean] Error 2
~/Desktop/ray/src
~/Desktop/ray/src/hd ~/Desktop/ray/src
In directory hd...
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rholo.o rholo.c
rholo.c: In function ‘creatholo’:
rholo.c:477: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
rholo.c:485: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
rholo.c: In function ‘loadholo’:
rholo.c:558: warning: ignoring return value of ‘read’, declared with attribute warn_unused_result
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rholo2.o rholo2.c
rholo2.c: In function ‘getradfile’:
rholo2.c:350: warning: ignoring return value of ‘mktemp’, declared with attribute warn_unused_result
rholo2.c:374: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rholo2l.o rholo2l.c
rholo2l.c: In function ‘start_rtrace’:
rholo2l.c:70: warning: ignoring return value of ‘mktemp’, declared with attribute warn_unused_result
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rholo3.o rholo3.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rholo4.o rholo4.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o holo.o holo.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o holofile.o holofile.c
holofile.c: In function ‘hdinit’:
holofile.c:249: warning: format ‘%ld’ expects type ‘long int’, but argument 3 has type ‘off_t’
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o viewbeams.o viewbeams.c
cp ../rt/Version.c .
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o Version.o Version.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -o rholo rholo.o rholo2.o rholo2l.o rholo3.o rholo4.o \
holo.o holofile.o viewbeams.o Version.o -lrtrad -lm
rholo2.o: In function `getradfile':
rholo2.c:(.text+0x25e): warning: the use of `mktemp' is dangerous, better use `mkstemp' or `mkdtemp'
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rhpict.o rhpict.c
rhpict.c: In function ‘initialize’:
rhpict.c:307: warning: ignoring return value of ‘read’, declared with attribute warn_unused_result
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rhpict2.o rhpict2.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -o rhpict rhpict.o rhpict2.o holo.o holofile.o \
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rhcopy.o rhcopy.c
rhcopy.c: In function ‘openholo’:
rhcopy.c:156: warning: ignoring return value of ‘read’, declared with attribute warn_unused_result
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o clumpbeams.o clumpbeams.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -o rhcopy rhcopy.o clumpbeams.o \
holo.o holofile.o -lrtrad -lm
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o genrhgrid.o genrhgrid.c
genrhgrid.c: In function ‘gridsect’:
genrhgrid.c:76: warning: ignoring return value of ‘read’, declared with attribute warn_unused_result
genrhgrid.c:78: warning: ignoring return value of ‘read’, declared with attribute warn_unused_result
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -o genrhgrid genrhgrid.o holo.o -lrtrad -lm
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rhoptimize.o rhoptimize.c
rhoptimize.c: In function ‘main’:
rhoptimize.c:79: warning: ignoring return value of ‘read’, declared with attribute warn_unused_result
rhoptimize.c:84: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
rhoptimize.c:89: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -o rhoptimize rhoptimize.o clumpbeams.o \
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rhinfo.o rhinfo.c
rhinfo.c: In function ‘gethdinfo’:
rhinfo.c:69: warning: ignoring return value of ‘read’, declared with attribute warn_unused_result
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -o rhinfo rhinfo.o holo.o holofile.o -lrtrad -lm
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rhdisp.o rhdisp.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rhdisp2.o rhdisp2.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rhd_x11.o rhd_x11.c
rhd_x11.c:11:23: error: X11/Xlib.h: No such file or directory
rhd_x11.c:12:29: error: X11/cursorfont.h: No such file or directory
rhd_x11.c:13:24: error: X11/Xutil.h: No such file or directory
rhd_x11.c:61: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘currentevent’
rhd_x11.c:68: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
rhd_x11.c:69: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘ourvinfo’
rhd_x11.c:70: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘gwind’
rhd_x11.c:71: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘ourgc’
rhd_x11.c:72: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘ourmap’
rhd_x11.c:91: error: expected ‘)’ before ‘*’ token
rhd_x11.c:93: error: expected ‘)’ before ‘*’ token
rhd_x11.c:94: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
rhd_x11.c:95: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
rhd_x11.c:96: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
rhd_x11.c: In function ‘dev_open’:
rhd_x11.c:129: error: ‘XSetWindowAttributes’ undeclared (first use in this function)
rhd_x11.c:129: error: (Each undeclared identifier is reported only once
rhd_x11.c:129: error: for each function it appears in.)
rhd_x11.c:129: error: expected ‘;’ before ‘ourwinattr’
rhd_x11.c:130: error: ‘XWMHints’ undeclared (first use in this function)
rhd_x11.c:130: error: expected ‘;’ before ‘ourxwmhints’
rhd_x11.c:131: error: ‘XSizeHints’ undeclared (first use in this function)
rhd_x11.c:131: error: expected ‘;’ before ‘oursizhints’
rhd_x11.c:135: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c:141: error: ‘TrueColor’ undeclared (first use in this function)
rhd_x11.c:141: error: ‘ourvinfo’ undeclared (first use in this function)
rhd_x11.c:143: error: ‘DirectColor’ undeclared (first use in this function)
rhd_x11.c:152: error: ‘PseudoColor’ undeclared (first use in this function)
rhd_x11.c:154: error: ‘GrayScale’ undeclared (first use in this function)
rhd_x11.c:160: warning: assignment makes pointer from integer without a cast
rhd_x11.c:174: error: ‘ourwinattr’ undeclared (first use in this function)
rhd_x11.c:176: error: ‘StructureNotifyMask’ undeclared (first use in this function)
rhd_x11.c:176: error: ‘ExposureMask’ undeclared (first use in this function)
rhd_x11.c:176: error: ‘KeyPressMask’ undeclared (first use in this function)
rhd_x11.c:176: error: ‘ButtonPressMask’ undeclared (first use in this function)
rhd_x11.c:176: error: ‘ButtonReleaseMask’ undeclared (first use in this function)
rhd_x11.c:179: error: ‘AllocNone’ undeclared (first use in this function)
rhd_x11.c:180: error: ‘gwind’ undeclared (first use in this function)
rhd_x11.c:183: error: ‘InputOutput’ undeclared (first use in this function)
rhd_x11.c:184: error: ‘CWBackPixel’ undeclared (first use in this function)
rhd_x11.c:184: error: ‘CWBorderPixel’ undeclared (first use in this function)
rhd_x11.c:184: error: ‘CWColormap’ undeclared (first use in this function)
rhd_x11.c:184: error: ‘CWEventMask’ undeclared (first use in this function)
rhd_x11.c:189: error: ‘ourgc’ undeclared (first use in this function)
rhd_x11.c:191: error: ‘ourxwmhints’ undeclared (first use in this function)
rhd_x11.c:191: error: ‘InputHint’ undeclared (first use in this function)
rhd_x11.c:191: error: ‘IconPixmapHint’ undeclared (first use in this function)
rhd_x11.c:192: error: ‘True’ undeclared (first use in this function)
rhd_x11.c:196: error: ‘oursizhints’ undeclared (first use in this function)
rhd_x11.c:198: error: ‘PMinSize’ undeclared (first use in this function)
rhd_x11.c: In function ‘dev_close’:
rhd_x11.c:224: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c:224: error: ‘ourgc’ undeclared (first use in this function)
rhd_x11.c:225: error: ‘gwind’ undeclared (first use in this function)
rhd_x11.c: In function ‘dev_view’:
rhd_x11.c:269: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c:286: error: ‘gwind’ undeclared (first use in this function)
rhd_x11.c: In function ‘dev_input’:
rhd_x11.c:338: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c: In function ‘dev_paintr’:
rhd_x11.c:363: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c:363: error: ‘ourgc’ undeclared (first use in this function)
rhd_x11.c:364: error: ‘gwind’ undeclared (first use in this function)
rhd_x11.c: In function ‘dev_flush’:
rhd_x11.c:374: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c: In function ‘xnewcolr’:
rhd_x11.c:386: error: ‘XColor’ undeclared (first use in this function)
rhd_x11.c:386: error: expected ‘;’ before ‘xcolor’
rhd_x11.c:388: error: ‘xcolor’ undeclared (first use in this function)
rhd_x11.c:392: error: ‘DoRed’ undeclared (first use in this function)
rhd_x11.c:392: error: ‘DoGreen’ undeclared (first use in this function)
rhd_x11.c:392: error: ‘DoBlue’ undeclared (first use in this function)
rhd_x11.c:394: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c:394: error: ‘ourmap’ undeclared (first use in this function)
rhd_x11.c: In function ‘getpixels’:
rhd_x11.c:401: error: ‘XColor’ undeclared (first use in this function)
rhd_x11.c:401: error: expected ‘;’ before ‘thiscolor’
rhd_x11.c:406: error: ‘ourvinfo’ undeclared (first use in this function)
rhd_x11.c:406: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c:407: error: ‘ourmap’ undeclared (first use in this function)
rhd_x11.c:411: error: ‘gwind’ undeclared (first use in this function)
rhd_x11.c:411: error: ‘AllocNone’ undeclared (first use in this function)
rhd_x11.c:434: error: ‘thiscolor’ undeclared (first use in this function)
rhd_x11.c:435: error: ‘DoRed’ undeclared (first use in this function)
rhd_x11.c:435: error: ‘DoGreen’ undeclared (first use in this function)
rhd_x11.c:435: error: ‘DoBlue’ undeclared (first use in this function)
rhd_x11.c: In function ‘freepixels’:
rhd_x11.c:455: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c:455: error: ‘ourmap’ undeclared (first use in this function)
rhd_x11.c: In function ‘true_pixel’:
rhd_x11.c:472: error: ‘ourvinfo’ undeclared (first use in this function)
rhd_x11.c: In function ‘getevent’:
rhd_x11.c:482: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c:482: error: ‘XEvent’ undeclared (first use in this function)
rhd_x11.c:482: error: expected expression before ‘)’ token
rhd_x11.c:483: error: expected expression before ‘)’ token
rhd_x11.c:484: error: ‘ConfigureNotify’ undeclared (first use in this function)
rhd_x11.c:485: error: ‘XConfigureEvent’ undeclared (first use in this function)
rhd_x11.c:485: error: expected expression before ‘)’ token
rhd_x11.c:487: error: ‘UnmapNotify’ undeclared (first use in this function)
rhd_x11.c:491: error: ‘MapNotify’ undeclared (first use in this function)
rhd_x11.c:492: error: ‘ourvinfo’ undeclared (first use in this function)
rhd_x11.c:492: error: ‘PseudoColor’ undeclared (first use in this function)
rhd_x11.c:493: error: ‘GrayScale’ undeclared (first use in this function)
rhd_x11.c:500: error: ‘Expose’ undeclared (first use in this function)
rhd_x11.c:501: error: ‘XExposeEvent’ undeclared (first use in this function)
rhd_x11.c:501: error: expected expression before ‘)’ token
rhd_x11.c:503: error: ‘KeyPress’ undeclared (first use in this function)
rhd_x11.c:504: error: ‘XKeyPressedEvent’ undeclared (first use in this function)
rhd_x11.c:504: error: expected expression before ‘)’ token
rhd_x11.c:506: error: ‘ButtonPress’ undeclared (first use in this function)
rhd_x11.c:507: error: ‘XButtonPressedEvent’ undeclared (first use in this function)
rhd_x11.c:507: error: expected expression before ‘)’ token
rhd_x11.c:507: error: ‘ShiftMask’ undeclared (first use in this function)
rhd_x11.c:507: error: ‘ControlMask’ undeclared (first use in this function)
rhd_x11.c:508: error: expected expression before ‘)’ token
rhd_x11.c:510: error: expected expression before ‘)’ token
rhd_x11.c: In function ‘draw3dline’:
rhd_x11.c:564: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c:564: error: ‘gwind’ undeclared (first use in this function)
rhd_x11.c:564: error: ‘ourgc’ undeclared (first use in this function)
rhd_x11.c: In function ‘draw_grids’:
rhd_x11.c:580: error: ‘ourdisplay’ undeclared (first use in this function)
rhd_x11.c:580: error: ‘ourgc’ undeclared (first use in this function)
rhd_x11.c: At top level:
rhd_x11.c:640: error: expected ‘)’ before ‘*’ token
rhd_x11.c:682: error: expected ‘)’ before ‘*’ token
rhd_x11.c:724: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
rhd_x11.c:806: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
rhd_x11.c:820: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
make: *** [rhd_x11.o] Error 1
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rhd_qtree.o rhd_qtree.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rhd_qtree2r.o rhd_qtree2r.c
gcc -I../common -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DDEVPATH=\"/usr/local/bin/dev\" -c -o rhd_ctab.o rhd_ctab.c
set nonomatch; rm -f *.o rholo rhpict rhcopy genrhgrid rhoptimize rhinfo core Version.c
~/Desktop/ray/src
~/Desktop/ray/src/util ~/Desktop/ray/src
In directory util...
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o findglare.o findglare.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o glareval.o glareval.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o glaresrc.o glaresrc.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o setscan.o setscan.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o findglare findglare.o glareval.o glaresrc.o \
setscan.o -lrtrad -lm
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o glarendx.o glarendx.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o glarendx glarendx.o -lrtrad -lm
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o rpiece.o rpiece.c
rpiece.c: In function ‘init’:
rpiece.c:246: warning: ignoring return value of ‘fscanf’, declared with attribute warn_unused_result
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o Version.o Version.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o rpiece rpiece.o Version.o -lrtrad -lm
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o rad.o rad.c
rad.c: In function ‘oconv’:
rad.c:552: warning: ignoring return value of ‘mktemp’, declared with attribute warn_unused_result
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o rad rad.o -lrtrad -lm
rad.o: In function `oconv':
rad.c:(.text+0x10dd): warning: the use of `mktemp' is dangerous, better use `mkstemp' or `mkdtemp'
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o ranimate.o ranimate.c
ranimate.c: In function ‘getradfile’:
ranimate.c:528: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o netproc.o netproc.c
netproc.c: In function ‘addpserver’:
netproc.c:61: warning: ignoring return value of ‘getcwd’, declared with attribute warn_unused_result
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o ranimate ranimate.o netproc.o -lrtrad -lm
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o ranimove.o ranimove.c
ranimove.c: In function ‘getradfile’:
ranimove.c:422: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result
ranimove.c:435: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o ranimove1.o ranimove1.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o ranimove2.o ranimove2.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o ranimove ranimove.o ranimove1.o ranimove2.o \
-lraycalls -lradiance -lrtrad -lm
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o vwright.o vwright.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o vwright vwright.o -lrtrad -lm
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o getinfo.o getinfo.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o getinfo getinfo.o -lrtrad
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o vwrays.o vwrays.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o vwrays vwrays.o -lrtrad -lm
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o xglaresrc.o xglaresrc.c
xglaresrc.c:14:22: error: X11/Xlib.h: No such file or directory
xglaresrc.c:15:23: error: X11/Xutil.h: No such file or directory
xglaresrc.c:32: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
xglaresrc.c:37: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘vecGC’
xglaresrc.c:38: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘gwind’
xglaresrc.c: In function ‘init’:
xglaresrc.c:95: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘xfindwind’
xglaresrc.c:96: error: ‘XWindowAttributes’ undeclared (first use in this function)
xglaresrc.c:96: error: (Each undeclared identifier is reported only once
xglaresrc.c:96: error: for each function it appears in.)
xglaresrc.c:96: error: expected ‘;’ before ‘wa’
xglaresrc.c:97: error: ‘XColor’ undeclared (first use in this function)
xglaresrc.c:97: error: expected ‘;’ before ‘xc’
xglaresrc.c:98: error: ‘XGCValues’ undeclared (first use in this function)
xglaresrc.c:98: error: expected ‘;’ before ‘gcv’
xglaresrc.c:108: error: ‘theDisplay’ undeclared (first use in this function)
xglaresrc.c:124: error: ‘gwind’ undeclared (first use in this function)
xglaresrc.c:125: error: ‘None’ undeclared (first use in this function)
xglaresrc.c:133: warning: missing sentinel in function call
xglaresrc.c:146: error: ‘wa’ undeclared (first use in this function)
xglaresrc.c:148: error: ‘IsViewable’ undeclared (first use in this function)
xglaresrc.c:162: error: ‘gcv’ undeclared (first use in this function)
xglaresrc.c:168: error: ‘xc’ undeclared (first use in this function)
xglaresrc.c:171: error: ‘DoRed’ undeclared (first use in this function)
xglaresrc.c:171: error: ‘DoGreen’ undeclared (first use in this function)
xglaresrc.c:171: error: ‘DoBlue’ undeclared (first use in this function)
xglaresrc.c:177: error: ‘vecGC’ undeclared (first use in this function)
xglaresrc.c:178: error: ‘GCForeground’ undeclared (first use in this function)
xglaresrc.c:178: error: ‘GCBackground’ undeclared (first use in this function)
xglaresrc.c:178: error: ‘GCFont’ undeclared (first use in this function)
xglaresrc.c:179: error: ‘strGC’ undeclared (first use in this function)
xglaresrc.c:181: error: ‘GXinvert’ undeclared (first use in this function)
xglaresrc.c:182: error: ‘GCFunction’ undeclared (first use in this function)
xglaresrc.c: In function ‘circle_sources’:
xglaresrc.c:205: error: ‘theDisplay’ undeclared (first use in this function)
xglaresrc.c: In function ‘circle’:
xglaresrc.c:229: error: ‘XPoint’ undeclared (first use in this function)
xglaresrc.c:229: error: expected ‘;’ before ‘pt’
xglaresrc.c:247: error: ‘pt’ undeclared (first use in this function)
xglaresrc.c:250: error: ‘theDisplay’ undeclared (first use in this function)
xglaresrc.c:250: error: ‘gwind’ undeclared (first use in this function)
xglaresrc.c:250: error: ‘vecGC’ undeclared (first use in this function)
xglaresrc.c:250: error: ‘CoordModeOrigin’ undeclared (first use in this function)
xglaresrc.c: In function ‘value’:
xglaresrc.c:277: error: ‘theDisplay’ undeclared (first use in this function)
xglaresrc.c:277: error: ‘gwind’ undeclared (first use in this function)
xglaresrc.c:277: error: ‘strGC’ undeclared (first use in this function)
make: *** [xglaresrc.o] Error 1
cp ../common/x11findwind.c .
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o x11findwind.o x11findwind.c
x11findwind.c:13:22: error: X11/Xlib.h: No such file or directory
x11findwind.c:17: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘xfindwind’
make: *** [x11findwind.o] Error 1
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o rtcontrib.o rtcontrib.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o rtcontrib rtcontrib.o Version.o -lrtrad -lm
rtcontrib.o: In function `main':
rtcontrib.c:(.text+0x3c1e): warning: the use of `mktemp' is dangerous, better use `mkstemp' or `mkdtemp'
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o rsensor.o rsensor.c
rsensor.c: In function ‘load_sensor’:
rsensor.c:221: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
rsensor.c:223: warning: ignoring return value of ‘fgets’, declared with attribute warn_unused_result
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o rsensor rsensor.o \
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -c -o dctimestep.o dctimestep.c
gcc -I../common -I../rt -L../lib -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -o dctimestep dctimestep.o -lrtrad -lm
set nonomatch; rm -f *.o findglare glarendx rpiece rad ranimate ranimove vwright getinfo vwrays xglaresrc rtcontrib rsensor dctimestep glrad core Version.c x11findwind.c
~/Desktop/ray/src
~/Desktop/ray/src/cal ~/Desktop/ray/src
In directory cal...
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -c -o calc.o calc.c
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -o icalc calc.o -lrtrad -lm
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -c -o ev.o ev.c
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -o ev ev.o -lrtrad -lm
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -c -o rcalc.o rcalc.c
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -o rcalc rcalc.o -lrtrad -lm
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -c -o total.o total.c
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -o total total.o -lm
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -c -o cnt.o cnt.c
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -o cnt cnt.o
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -c -o neat.o neat.c
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -o neaten neat.o
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -c -o lam.o lam.c
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -o rlam lam.o
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -c -o tabfunc.o tabfunc.c
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -o tabfunc tabfunc.o -lrtrad -lm
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -c -o histo.o histo.c
gcc -O2 -Dlinux -D_FILE_OFFSET_BITS=64 -L/usr/X11R6/lib -I/usr/include/X11 -DNOSTEREO -DBIGGERLIB -I../common -L../lib -o histo histo.o -lm
cp icalc ev rcalc total cnt neaten rlam tabfunc histo /usr/local/bin
set nonomatch; rm -f *.o icalc ev rcalc total cnt neaten rlam tabfunc histo
~/Desktop/ray/src
nyclinux@nyclinux:~/Desktop/ray$
