The short version of the question is:
- Is it fine for
rtrace -osTs
to name a number of polygons the same?
And here is why I need it:
I’m dealing with a large model in which I’m using this method to find from which window and in which time a sensor sees the sun. There are several windows in the mode and I want to name some of them the same as they technically represent the same window. I can name them as pl_1, pl_2 and so on and take care of grouping them when I parse the results but it will be much faster to group them by an identical name.
I did a quick render and it seems radiance loads the polygons fine even though they have the same name but I wonder if this will cause an issue in my case. Does it affect any internal indexing that can be problematic?
