Dear Group
As a personal project of mine, I wanted to integrate the M�ller-Trumbore (see white paper at http://www.graphics.cornell.edu/pubs/1997/MT97.html) algorithm for ray-triangle intersection into Radiance. The reason why I chose this algorithm is because it was simple to implement and for front facing, early division can be avoided. I have read the white paper and the math all checks out. The algorithm has been out for some time and has been implemented in numerous other raytracers. I have not heard any problems with the algorithm but in my own implementation neither the algorithm for front or back facing seem to work properly. I have check the code, which was adapted from the source code given in the paper, but it still doesn�t work like it should. I have thrown my hands up because I do not know what I have done wrong. I have considered the Segura-Feito method (implemented in o_mesh.c) but the problem here is that this method isn�t ray-triangle intersection but segment-triangle intersection. The only way that I know of how to calculate the ray segment length is find the ray length via ray-plane intersection. Unfortunately, this requires division which negates the primary advantage of the Segura-Feito method. Here is the modified version of o_face.c that I have been working on for M�ller-Trumbore. Any help�. Please?
Marcus
#ifndef lint
static const char RCSid[] = "$Id: o_face.c,v 2.4 2003/03/11 17:08:55 greg Exp $";
#endif
* o_face.c - compute ray intersection with faces.
#include "copyright.h"
#include "ray.h"
#include "face.h"
#include "standard.h"
#include "object.h"
#include "fvect.h"
o_face(o, r) /* compute intersection with polygonal face */
OBJREC *o;
register RAY *r;
double rdot; /* direction . normal */
double t; /* distance to intersection */
FVECT pisect; /* intersection point */
register FACE *f; /* face record */
register int i;
f = getface(o);
* First, we find the distance to the plane containing the
* face. If this distance is less than zero or greater
* than a previous intersection, we return. Otherwise,
* we determine whether in fact the ray intersects the
* face. The ray intersects the face if the
* point of intersection with the plane of the face
* is inside the face.
/* compute dist. to plane */
if(f->nv == 3)
if (intersect_triangle(r,f) == 0)
return(0);
else
rdot = -DOT(r->rdir, f->norm);
if (rdot <= FTINY && rdot >= -FTINY) /* ray parallels plane */
t = FHUGE;
else
t = (DOT(r->rorg, f->norm) - f->offset) / rdot;
if (t <= FTINY || t >= r->rot) /* not good enough */
return(0);
/* compute intersection */
for (i = 0; i < 3; i++)
pisect[i] = r->rorg[i] + r->rdir[i]*t;
if (!inface(pisect, f)) /* ray intersects face? */
return(0);
r->rot = t;
VCOPY(r->rop, pisect);
r->rod = rdot;
r->ro = o;
VCOPY(r->ron, f->norm);
r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
r->uv[0] = r->uv[1] = 0.0;
r->rox = NULL;
return(1); /* hit */
/* The following function is adapted from the M�ller-Trumbore algorithm ***/
int
intersect_triangle(r, f)
FACE *f;
register RAY *r;
double *u, *v, *t;
double det,inv_det, d;
int i;
double rdot;
FVECT tvec, pvec, qvec, edge1, edge2;
VSUB(edge1, VERTEX(f,1), VERTEX(f,0));
VSUB(edge2, VERTEX(f,2), VERTEX(f,0));
/* begin calculating determinant - also used to calculate U parameter */
VCROSS(pvec, r->rdir, edge2);
/* if determinant is near zero, ray lies in plane of triangle */
det = DOT(edge1, pvec);
if (det > -FTINY && det < FTINY)
return 0;
inv_det = 1.0 / det;
/* calculate distance from vert0 to ray origin */
VSUB(tvec, r->rorg, VERTEX(f,0));
/* calculate U parameter and test bounds */
*u = DOT(tvec, pvec)* inv_det;
if (*u < 0.0 || *u > 1.0)
return 0;
/* prepare to test V parameter */
VCROSS(qvec, tvec, edge1);
/* calculate V parameter and test bounds */
*v = DOT(r->rdir, qvec) * inv_det;
if (*v < 0.0 || *u + *v > 1.0)
return 0;
/* calculate t, scale parameters, ray intersects triangle */
*t = DOT(edge2, qvec) * inv_det;
if (*t <= FTINY || *t >= r->rot) /* not good enough */
return(0);
r->rot = *t;
r->rod = rdot;
r->rop[i] = r->rorg[i] + r->rdir[i]* r->rot;
return 1;
MSN Movies - Trailers, showtimes, DVD's, and the latest news from Hollywood! http://movies.msn.click-url.com/go/onm00200509ave/direct/01/
