triangulate radiance scene
Hi
Does anyone know how I could create a triangular mesh of a radiance scene such
as convert to .obj format or something like that?
Thanks
Tarik
Tarik Rahman
PhD student, Institue of Perception, Action and Behaviour
School of Informatics
University of Edinburgh
Hi Tarik,
Radiance offers the obj2rad converter to go from (Alias/Wavefront) .OBJ format to Radiance. However, it does so by expanding the mesh into individual triangles, which is not terribly space-efficient. If you don't apply the -f option, it also creates a texture for each triangle to produce a smoothed result if vertex normal data is included in the .OBJ file, which leads to further expansion of the model. This may not be a problem for small meshes, but it can add up to a lot of memory use for large ones.
A new alternative in the HEAD release is the obj2mesh converter, which compiles a .OBJ file into a "Radiance Triangle Mesh," a special kind of octree that may be instantiated in the scene using the new "mesh" primitive.
If you have a formula or vertex data points rather than a .OBJ file, you may use the gensurf command to convert it into Radiance polygons. The HEAD version of gensurf includes a -o option for outputting to .OBJ format, which may then be converted to an RTM using obj2mesh.
I hope this helps.
Date: September 27, 2004 8:37:32 AM PDT
Hi
Thanks
Tarik
Tarik Rahman
Hi Tarik!
So do you want to "export" the scene into another 3d-format ("as convert to obj"), or do you want to have a radiance scene of triangles? If the first is the case, the only way I know is rad2mgf, mgf2inv (which will produce inventor- or vrml-files).
CU Lars.
Lars O. Grobe
