I would like to model trees outside buildings in my Radiance runs. I would like to model them transmitting about 20% of light and make the canopy 40% reflective.
* Can I do this by using a translucent material?
* If so, can you point me to a tutorial?
* Will this be compatible with the 3-phase method of daylighting analysis? (I.e., daylight coefficient method with the 3-phase method and a BSDF for the window).
Thanks for any help,
Tim
Hi Tim,
You can do it with trans, and it will work with the 3-phase method. Here are some useful posts:
[Radiance-general] trans mat
[Radiance-general] trans dashboard widget
Hope this is enough to get you started!
Date: December 5, 2011 5:34:27 PM PST
Tim
Dear Greg,
Does the surface roughness matter if the reflected specularity (Rs) is zero?
Tim
PS: Is there a Radiance beginners list? I surely belong there.
PPS: Here is my full definition. I'm using pages 325-326 in Rendering With Radiance as my guide.
Diffuse reflectance (Rd = 40%)
Red: 25%Cr
Green: 70%Cg
Blue: 25%Cb
Reflected Specularity (Rs): 0
Surface Roughness (Sr): 0.0
Diffuse Transmissivity (Td) = 19%
Transmitted Specularity (Ts) = 1%
** Final Material **
void trans TransTreeMat
7 0.375 1.05 0.375 0 0 0.33333 0.05
To: Tim Perry <[email protected]>; Radiance general discussion <[email protected]>
Sent: Monday, December 5, 2011 5:48 PM
Subject: Re: [Radiance-general] Trees
Hi Tim,
Tim
Hi Tim,
The roughness will influence any transmitted specular component as well.
Your calculation of trans parameters is off because your Rd is not 40% using RGB of 25%, 70% and 25%. If you want 40% reflectance, you need to adjust the RGB to (0.181,0.508,0.181). I computed these based on the Y function in "ray/src/cal/cal/xyz_rgb.cal".
With these changes, I get:
7 0.272 0.761 0.272 0 0 0.33333 0.05
Does this make sense?
Date: December 6, 2011 12:31:15 PM PST
Dear Greg,
Tim
Red: 25%Cr
Green: 70%Cg
Blue: 25%Cb
Greg,
My mistake was taking the simple average, rather than the photopic average, right? I looked right past that adjective....
Thanks for catching my error,
Tim
----- Original Message -----
Cc: "[email protected]" <[email protected]>
Sent: Tuesday, December 6, 2011 5:32 PM
Hi Tim,
Dear Greg,
Tim
Red: 25%Cr
Green: 70%Cg
Blue: 25%Cb
