translucent glass
Hello Everybody,
I am now modelling my skylight case, a 36' x30' room
with four 4' x 4' skylights distributed evenly.(well
depth 3'). In my Doe 2 model I am using a flat glass
which has properties similar to that of a
2 dome fiberglass(translucent) with Visible
transmittance = 0.5, SC = 0.45
I need to create a similar glass type in Radiance.
I am using the trans material type and based a on
previous discussion have created
void trans skylight
7 0.54 0.54 0.54 0 0 1 0
Is this the correct material definition.
What would be the definition for a similar white
translucent material.(Would the color effect the
illuminance values inside)
Also I know that I need to use mkillum for this.Do I
need to define both the window surface as well as a
polygon below the well as illums or simply the polygon
below the well so as to obtain accurate results.
Please Guide me with this.
Thank You
Arvinder
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
Hi Arvinder,
Date: Fri Oct 24, 2003 5:01:34 PM US/Pacific
Hello Everybody,
void trans skylight
How did you come up with 0.54 for the diffuse? I would have expected this to be 0.50 if all you wanted was a 50% visible transmittance. However, there is no material that transmits 50% of the visible diffusely without also reflecting a fair amount. Given that you only care about the interior values, I suppose it doesn't matter in this case, but a more realistic model would be:
void trans skylight
7 1 1 1 0 0 0.5 0
This would be an ideal scattering surface, spreading the incident radiation equally in all directions, 50% transmitted and 50% reflected. There is no such material in the real world, but some materials come reasonably close. The diffuser is white because all of the components (red green and blue) are equal. A colored surface would affect the illuminances somewhat.
In this special diffuse case, you can hand the skylight polygons to mkillum directly, setting
#@mkillum d=0 c=n l-
In the scene file to compute a total average diffuse light source for each surface using mkillum. There is no sense in creating illum's (as opposed to light sources) because there is nothing to see through such a diffuser, and no sunlight will penetrate it.
