trans
Since about 10 months, I am having an unexpected problem with the material trans. The direct component (argument 7) always cases 0 illuminance values. Was there a change in the material definition?
Martin Moeck
Hi Martin,
I'm not sure I understand your question. Could you restate it more clearly?
Are you speaking of the rpict/rtrace -i+ rendering option? In this case, trans materials will be ignored, treated as if they were not there at all, regardless of the real arguments. The same is true for dielectric and glass materials. This is designed to avoid the confusing situation where you see the irradiance arriving at a window rather than the irradiance on the objects visible through it.
Date: January 2, 2006 10:32:51 AM PST
Martin Moeck
Example:
rtrace -h -w -I -ab 2 -dr 2 -ds 2 octree < points.inp | rcalc ...
points.inp contains the location and direction of a sensor in front of and then behind the trans material for the calculation of total transmittance.
Martin
Sent: Mon 1/2/2006 1:47 PM
Subject: Re: [Radiance-general] trans
Hi Martin,
clearly?
Martin Moeck
Hi Martin,
You still aren't giving enough hints as to your problem. What is your scene? Which version of Radiance are you using?
I just ran a few sanity checks with the rtrace -I option and the latest HEAD release on a trans material, and all seems well.
Date: January 2, 2006 11:17:34 AM PST
Example:
Martin
Radiance 3.5 official LBNL release March 21 2003
Scene = a box 3X3X3 m with a south facing window.
Trans =
0.31 0.31 0.31 0.01 0.02 0.3443 0.191
points.inp:
1.5 -.5 1.5 0 -1 0
1.5 0.1 1.5 0 -1 0
I assume the following formulae:
ts = direct transmittance = 0.02
td = diffuse transmittance = 0.85
rs_a = ts_a = roughness = 0.02
rs = specularity
A1 = A2 = A3 = rd / ( (1-rs)*(1-A6) )
A4 = rs = 0.01
A5 = (rs * rs_a _ ts * ts_a) / (rs + ts)
A6 = (td + ts) / (rd + td + ts)
A7 = ts / (td + ts)
Is that correct?
Martin
Sent: Mon 1/2/2006 2:42 PM
Hi Martin,
Example:
transmittance.
Martin
Hi Martin,
Thanks for writing to let me know all is well with trans, if a bit confusing... (But we knew that!)
While I agree that the -i option would be better to show arriving irradiance on some trans surfaces, it's a hack to begin with, and the behavior is more predictable if it switches based on material type rather than material parameters.
Your formulas for the trans arguments look correct, except your A5 calculation, the specular roughness:
Perhaps you meant:
A5 = (rs * rs_a + ts * ts_a) / (rs + ts)
This seems a reasonable way to compute an average value for the roughness.
------------------ Off-list messages:
Date: January 3, 2006 3:19:22 PM PST
Greg,
I dutifully updated to 3.7 patchlevel 2 today.
Your HDR book is great.
Trans is ok - I made a mistake and got thrown off additionally by the to me yet unfamiliar rview -i trans and glass appearance. In my opinion, these surfaces should show their illuminance levels. They are planes with non-emitting materials.
I hope I did not make a mistake in the trans A1-A7 calculations.
Martin
Date: January 2, 2006 12:48:18 PM PST
Hi Martin,
Just so I don't have to recreate it myself and get some detail wrong, could you send me your scene file(s) in a separate e-mail (not to the list)?
P.S. Why are you 2 releases behind??
------- Original post:
Date: January 2, 2006 12:08:51 PM PST
Trans =
points.inp:
1.5 -.5 1.5 0 -1 0
1.5 0.1 1.5 0 -1 0
rs = specularity
A4 = rs = 0.01
A7 = ts / (td + ts)
Is that correct?
Martin
Hi Martin,
