Trans material sample with dynamic daylight simulation (rcontrib)
hallo everyone,
I would like to ask you a favor: if anyone is able to send me a sample
project or simple room with trans material, with results, which i can
simulate in my computer. I am trying to simulate a project with dynamic
daylight simulation (dds / rcontrib) but i am not able to say if the
results are correct or not.
in other word, i need a reference so to check if the results (according to
my settings) i am getting are fine or not.
thx in advance,
*N.Nassif
Lighting Designer***
*PLDA Member
Along the same lines, you can increase the -ss setting to 32 or 64 to get better specular sampling with trans and BSDF types.
Sent from my iPad
On Jul 24, 2013, at 9:31 AM, Andrew McNeil <[email protected]> wrote:
I don't have a sample project you can run, but I can offer some advice:
A standard daylight coefficient run with a trans material (or BSDF) is finicky because the the sky is sampled stochastically without regard to the position of the sun. If your sampling density is low or you use a high resolution sky descretization scheme you might not fully sample the sky, missing patches. If the sun happens to be in a missed patch your result will under estimate the illuminance.
I'd recommend using high -ad parameter, low -lw parameter and use the tregenza sky (not reinhart). Or better yet, use the 3-phase method.
I'd recommend running a few static sky conditions with rtrace to compare with your DDS results.
Andy
On Wed, Jul 24, 2013 at 1:53 AM, nassif nassif <[email protected]> wrote:
hallo everyone,
I would like to ask you a favor: if anyone is able to send me a sample project or simple room with trans material, with results, which i can simulate in my computer. I am trying to simulate a project with dynamic daylight simulation (dds / rcontrib) but i am not able to say if the results are correct or not.
in other word, i need a reference so to check if the results (according to my settings) i am getting are fine or not.
thx in advance,
N.Nassif
Lighting Designer
PLDA Member
