three-phase method
hi all
i am trying three-phase method with three-phase method tutorial.
i have error with example 1.
i finished to make directory by using mkdir...
but i have error with following command.
vwrays -ff -vf views/back.vf -x 600 -y 600 |\
rtcontrib 'vwrays -vf views/back.vf -x 600 -y 600 -d' -ffc \
-fo -o images/vmx/window_%03d.hdr\
-f klems_int.cal -b kbinS -bn Nkbins -m windowlight \
-ab 2 -ad 1000 -ds .15 -lw le-4 model_vmx.oct
error message
rtrace: fatal - command line error at 'vwrays -vf views/back.vf -x 600 -y 600 -d'
anyone who knows the solution?
ogata
Hi Ogata,
You need to use the backwards single-quote in that part of the command line (ASCII code 96). Or, you can substitute the output of the command at that point in the command line, instead.
Date: February 19, 2013 5:50:56 PM PST
hi all
error message
ogata
hi greg,
thank you for your advice! i was able to proceed to the next stage.
i finished the example 1. now i am tying to the example 2.
but i have the new error with the following command.
rtcontrib -f klems_int.cal -bn Nkbins -fo -o results/photocells_%s.vmx -b kbinS -m window_south -b kbinE -m window_east -I+ -ab 3 -ad 2000 -ds .15 -lw 1e-4 model2_vmx.oct<data/photocells.pts
error message
segmentation fault (core dumped)
please advice me.
ogata
----- Original Message -----
To: [email protected]; Radiance general discussion <[email protected]>
Date: 2013/2/20, Wed 11:05
Subject: Re: [Radiance-general] three-phase method
Hi Ogata,
hi all
error message
ogata
Hi Ogata,
I don't see anything visibly wrong with your command line. Core dumps in general should not happen, but can if the command line arguments are badly wrong since some programs don't check argument counts carefully. I think the new rcontrib does, but I don't know for sure about rtcontrib. In any case, I don't see anything obvious here. What happens when you type "rtcontrib -version" by itself on the command line? What happens if you type "rcontrib -version?"
Date: March 5, 2013 11:54:48 PM PST
hi greg,
error message
please advice me.
ogata
Hi Ogata,
hi all
error message
ogata
I might say the obvious, but I had that problem some time ago (if I
remember well), and it was a problem with Radiance installation. Does it
say "Done" when you finish that?
German
2013/3/6 Greg Ward <[email protected]>
Hi Ogata,
*Date: *March 5, 2013 11:54:48 PM PST
hi greg,
error message
please advice me.
ogata
*To:* [email protected]; Radiance general discussion <
[email protected]>
*Date:* 2013/2/20, Wed 11:05
*Subject:* Re: [Radiance-general] three-phase method
Hi Ogata,
*Date: *February 19, 2013 5:50:56 PM PST
hi all
error message
600 -d'
ogata
thank you greg and german. i finished the example 1 and example 2.
i have new questions for the example 1. i made the figure 13, 18, 19, 20, 21. but results seem to be different than the manual. i have done as manual. what is wrong?
i attach a PDF file describing my results.
the diffarances between my results and the manual are as follows.
1. in figure 13, the order of the images seems to be different.
2. in figure 18, the illuminance in my results are bigger than the manual. also the venetian0 is bigger than the venetian45.
3. in figure 19-21, the distributitons of images are different with the manual. for example, in figure 21, the illuminance on the floor is bigger than other walls in our result. but in the manual, the value on the ceilling is bigger than other place.
4. etc
please help me!
ogata
example1_results.pdf (62.5 KB)
Cc: [email protected]
Date: 2013/3/7, Thu 04:54
I might say the obvious, but I had that problem some time ago (if I remember well), and it was a problem with Radiance installation. Does it say "Done" when you finish that?
German
Hi Ogata,
hi greg,
error message
please advice me.
ogata
Hi Ogata,
hi all
error message
ogata
Hi Ogata,
This tutorial was made in the early days of the 3-phase method. There have
been many bug fixes, including one where angles were mis-interpreted twice,
so the result for symmetric CFS was okay.
1 - Fixing the bug mentioned above affects the numbering of the view matrix
renderings. So your figure 13 is correct.
2 - in figure 18, the venetian0 and venetian 45 labeling is swapped. The
result isn't affected.
3 - this is strange, especially with part of the window showing up black.
Did you make sure to change to the W6 Standard basis in window (Figure 14
in the tutorial)?
I'm working on updating the tutorial to fix these issues and to incorporate
newer capabilities. Hopefully I have a new version this week.
Andy
4. etc
please help me!
ogata
*To:* Radiance general discussion <[email protected]>
*Cc:* [email protected]
*Date:* 2013/3/7, Thu 04:54
German
Hi Ogata,
hi greg,
error message
please advice me.
ogata
[email protected]>
Hi Ogata,
hi all
error message
600 -d'
ogata
Hi Ogata,
I've uploaded a revised version of the three-phase tutorial:
Andy
On Mon, Mar 18, 2013 at 4:52 PM, Andrew McNeil <[email protected]> wrote:
Hi Ogata,
have been many bug fixes, including one where angles were mis-interpreted
twice, so the result for symmetric CFS was okay.
matrix renderings. So your figure 13 is correct.
in the tutorial)?
incorporate newer capabilities. Hopefully I have a new version this week.
Andy
4. etc
please help me!
ogata
German
Hi Ogata,
hi greg,
error message
please advice me.
ogata
[email protected]>
Hi Ogata,
hi all
error message
600 -d'
ogata
