The Three-Phase Method for Simulating Complex Fenestration with Radiance
The latest version of dctimestep allows an output specification such as "-o sensor%02d.txt" to separate sensor files like you want.
Date: July 23, 2013 3:58:47 PM PDT
German,
Thank you for your response.
I actually tried exporting the results to excel. However, the huge text file needs some time consuming editing before the export.
I wonder if we could modify the scripts to pipe each sensor point data into a separate file with one set of R G B values in each line.
This will save me a lot of time.
Thank you,
Leyla
On Tue, Jul 23, 2013 at 3:01 PM, Germán Molina Larrain <[email protected]> wrote:
If I understand your question correctly, I guess I would do the rest on a spreadsheet or on a script.
For a spreadsheet, I would do:
rlam 'Results of venetian blind' 'Results of tinted' 'results of untinted' > Results.txt
rlam '!dctimestep -n 8760 results/photocells_windowglow_W.vmx xml/venetain80.xml results/windows.dmx Milwaukee.smx' '!dctimestep -n 8760 results/photocells_windowglow_C.vmx xml/tinted.xml results/clerestories.dmx Milwaukee.smx' '!dctimestep -n 8760 results/photocells_windowglow_C.vmx xml/untinted.xml results/clerestories.dmx Milwaukee.smx' > results/Results.txt
And, you should get, for each timestep, the parameter you are using for controlling the tint on your clerestories, and add that as an extra column.
Then, on excel it is possible to do:
> A | B | C | D | E |
> Venetian Results | Tinted Results | Untinted Results | Control Parameter | Final Results |
and put a formula to final result saying that, if(Control > theshold; Venetian+Tinted;Venetian+Untinted).
Hope it helps... I am working on something to do this kind of things on a single program, but it is not ready yet.
German
2013/7/23 Leyla Sanati <[email protected]>
Dear list,
I am trying to use the three phase method to calculate dynamic daylight performance metrics for a dynamic shading device. Similar to the example 2 in the three phase method tutorial, I have two sets of windows (clerestories and windows). I want to first calculate the annual illuminance levels on a 6 by 8 grid. Then filter the data by occupancy (normal working hours) and calculate the dynamic daylight metrics.
Since is the shading device in my model is dynamic and has to change based on the incident light, I have two BSDF files for each window (e.g. tinted.xml and untinted.xml).
I have created the vmx, dmx, xml, and smx files. But I am confused on how to write the dctimestep and the rest of the calculations. Bellow is what I have typed so far. I'd truly appreciate it if you could help me from this point on.
Thank you,
Leyla Sanati
oconv materials/room.mat objects/room.rad objects/windows.rad objects/clerestories.rad objects/ground.rad > model_vmx.oct
rcontrib -f klems_int.cal -bn Nkbins -fo -o results/photocells_%s.vmx -b kbinS -m windowglow_W -b kbinS -m windowglow_C -I+ -ab 12 -ad 50000 -lw 2e-5 model_vmx.oct < data/photocells.pts
oconv materials/room.mat objects/room.rad objects/ground.rad objects/sky_white1.rad > model_dmx.oct
genklemsamp -vd 0 -1 0 objects/windows.rad | rcontrib -c 1000 -e MF:4 -f reinhart.cal -b rbin -bn Nrbins -m sky_glow -faf model_dmx.oct > results/windows.dmx
genklemsamp -vd 0 -1 0 objects/clerestories.rad | rcontrib -c 1000 -e MF:4 -f reinhart.cal -b rbin -bn Nrbins -m sky_glow -faf model_dmx.oct > results/clerestories.dmx
epw2wea USA_WI_Milwaukee_TMY3.epw Milwaukee.wea
gendaymtx -m 4 Milwaukee.wea > Milwaukee.smx
rlam '!dctimestep -n 8760 results/photocells_windowglow_W.vmx xml/venetain80.xml results/windows.dmx Milwaukee.smx' '!dctimestep -n 8760 results/photocells_windowglow_C.vmx xml/tinted.xml results/clerestories.dmx Milwaukee.smx' > results/venetain80_tinted.dat
rlam '!dctimestep -n 8760 results/photocells_windowglow_W.vmx xml/venetain80.xml results/windows.dmx Milwaukee.smx' '!dctimestep -n 8760 results/photocells_windowglow_C.vmx xml/untinted.xml results/clerestories.dmx Milwaukee.smx' > results/venetain80_untinted.dat
Oh, oops! Guess that is the way it works, not the other way around. If you output into a single file as you were doing, the first 8760*3 values are the first sensor, the next 8760*3 are the next sensor, and so on. A simple sed script should work for separating them, and you can automate generating the sed script using rcalc. If you have 20 sensor, you would use:
% cnt 20 | rcalc -e 'a=8761*$1+2;b=8761*($1+1)' -o '${a},${b}w sensor${recno}.txt' > sedscr.txt
% [dctimestep command] | tr \\t \\n | sed -n -f sedscr.txt
For more or fewer sensors, just change the '20' in the first line. I haven't tried this, but it should work -- assuming you have tr and sed, that is...
Date: July 23, 2013 6:10:14 PM PDT
I added the "-o sensor%02d.txt" option to the dctimestep line, and it worked. But it created 8760 files for each time step rather than separating the sensors. Here is what I typed:
dctimestep -n 8760 -o results/Venetain80/sensor%02d.txt results/photocells_windowglow_W.vmx xml/venetain80.xml results/windows.dmx Milwaukee.smx
Leyla
German,
Thank you,
Leyla
> A | B | C | D | E |
German
Dear list,
Thank you,
Leyla Sanati
Hi Greg, Leyla,
I've just tried this out. The rcalc bit only works when a,b are up to
six digits long, which is 114 sensor points. rcalc goes into
exponential notation beyond this.
If you have more than 114 sensors, use this awk replacement instead:
cnt 115 | awk '{a=8761*$1+2; b=8761*($1+1); print a","b"w
sensor"NR".txt"}' > sedscr.txt
Regards
Axel
Hi Axel,
Thanks for the testing & the fix! I didn't think of the scientific notation issue....
I'm also embarrassed to admit that I never really learned how to use awk.
Date: July 24, 2013 6:29:44 AM PDT
Hi Greg, Leyla,
Regards
Axel
