the -r option
hello,
I have a model from rhino which i exported to .3ds, then i imported it
into sketchup in order to simplify the model and then finally i exported it
again in .3ds
After that, i imported it in ecotect because i want to do some lighthing
analysis and used radiance as well.
Even though I simplified the model I am still having the "set overflow in
addobject" error.
I read that i can change the -r option by powers of two until the problem
is fixed and i can render properly. The question is:
Where and how can I change that -r option?
*Ugo Testolini*
a r q u i t e c t o
*Maestría en Ciencias con especialidad en Diseño Eco-sustentable de
Edificios. Universidad de Cardiff, Reino Unido.*
*Maestría en Arquitectura con especialidad en Restauración de Monumentos.
ENCRyM-INAH*
*telcel: (045) 6681391316*
*[email protected]*
*www. <http://www.edbglobal.com>testolini.com*
THat error is rarely seen any more, if you are using a recent version of Radiance (oconv, actually). You can also try .obj format instead of .3ds. Both of these approaches will require you to use Radiance from the command line, though. It sounds like you're trying to use the Ecotect GUI for everything, which may not be possible -- I have no idea for certain, because I don't have a copy of Ecotect.
On Aug 29, 2013, at 12:56 PM, Hugo Testolini <[email protected]> wrote:
hello,
I have a model from rhino which i exported to .3ds, then i imported it into sketchup in order to simplify the model and then finally i exported it again in .3ds
After that, i imported it in ecotect because i want to do some lighthing analysis and used radiance as well.
Even though I simplified the model I am still having the "set overflow in addobject" error.
I read that i can change the -r option by powers of two until the problem is fixed and i can render properly. The question is:
Ugo Testolini
a r q u i t e c t o
Maestría en Ciencias con especialidad en Diseño Eco-sustentable de Edificios. Universidad de Cardiff, Reino Unido.
Maestría en Arquitectura con especialidad en Restauración de Monumentos. ENCRyM-INAH
www.testolini.com
thankyou, i will then update radiance and see what happen.
cheers!!
On Aug 29, 2013, at 12:56 PM, Hugo Testolini <[email protected]> > wrote:
> hello,
again in .3ds
> Cheers,
> Ugo Testolini
> a r q u i t e c t o
ENCRyM-INAH
> [email protected]
> www.testolini.com
> [email protected]
*Ugo Testolini*
a r q u i t e c t o
ENCRyM-INAH*
*[email protected]*
