I would like to use the program calc as in man pages and RwR, however, I can't find it anywhere.
Is it missing in action?
Paul
Hi Paul,
It got renamed, to eliminate a conflict. Try "icalc", I believe. Here's
the post that started it all:
http://www.radiance-online.org/pipermail/radiance-general/2003-December/001288.html
You could also create an alias called "the program formerly known as
calc", but that's messy.
Rob Guglielmetti
www.rumblestrip.org
Hi Paul,
The calc program has been renamed to "icalc" in 3.6 to avoid a naming conflict on some Unix systems. (The new name corresponds to "interactive calculator" if it helps you remember.) These are the name changes that were made in 3.6:
calc -> icalc
gencat -> gencatenary
lam -> rlam
neat -> neaten
rview -> rvu
The "rvu" program has a symbolic link to "rview," but still you'll get an invocation of the restricted, read-only version of "vi" on most systems unless you Radiance binaries are ahead of /usr/bin in your PATH variable.
-G
Date: May 4, 2005 2:46:15 PM PDTI would like to use the program calc as in man pages and RwR, however, I can't find it anywhere.
Paul
Greg and Rob G.
Thanks for the info. I'll make the necessary changes.
Paul
calc -> icalc
lam -> rlam
neat -> neaten
rview -> rvu
