I found the error causing the bounces within solids.
--__--__--
Message: 1
Date: Thu, 11 Jul 2002 14:14:32 -0400
To: <[email protected]>
Subject: [Radiance-general] Strange problem using -vtl to cut sections
Reply-To: [email protected]
This is a multi-part message in MIME format.
------_=_NextPart_001_01C22906.CE315366
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
=20
I am cutting plan and sectional views through a model for radiance
images, illuminance images using falsecolor, and point data output using
rtrace and have found the following problem: light is showing up inside
of fully closed boxes. For instance in plan view using -vtl and -o to
get a plan cut 4' off the floor I find that light appears to be
propagating inside of volumes with no holes. Running rtrace in these
areas also shows that a small amount of light is bouncing around inside
these solid shapes. =20
=20
The solution I plan on using is to model a flat plane at the bottom of
each of these spaces and give it a completely black plastic finish.
However it is a little disconcerting that light is entering the inside
of these boxes.
=20
Any ideas on the subject would be greatly appreciated.
=20
Thank you,
=20
Robert Westling
steinerwestling
Content-Type: text/html;
charset="us-ascii"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:[email protected]">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi,<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>I am cutting plan and sectional views through a model
for radiance
images, <span class=3DSpellE>illuminance</span> images using <span =
class=3DSpellE>falsecolor</span>,
and point data output using <span class=3DSpellE>rtrace</span> and have
found the
following problem:<span style=3D'mso-spacerun:yes'> </span>light =
is showing
up inside of fully closed boxes.<span style=3D'mso-spacerun:yes'>
</span>For instance in plan view using –<span =
class=3DSpellE>vtl</span> and
–o to get a plan cut 4’ off the floor I find that light =
appears to
be propagating inside of volumes with no holes.<span
style=3D'mso-spacerun:yes'> </span>Running <span =
in these areas also shows that a small amount of light is bouncing =
around
inside these solid shapes.<span style=3D'mso-spacerun:yes'> =
</span><o:p></o:p></span></font></p>
font-family:Arial'>The solution I plan on using is to model a flat plane
at the
bottom of each of these spaces and give it a completely black plastic
finish.<span style=3D'mso-spacerun:yes'> </span>However it is a =
little
disconcerting that light is entering the inside of these =
boxes.<o:p></o:p></span></font></p>
font-family:Arial'>Any ideas on the subject would be greatly =
appreciated.<o:p></o:p></span></font></p>
font-family:Arial'>Thank you,<o:p></o:p></span></font></p>
font-family:Arial'>Robert Westling<o:p></o:p></span></font></p>
font-family:Arial'>steinerwestling<o:p></o:p></span></font></p>
</div>
</body>
</html>
=00
------_=_NextPart_001_01C22906.CE315366--
--__--__--
Message: 2
Date: Thu, 11 Jul 2002 21:48:58 +0200
Subject: Re: [Radiance-general] Strange problem using -vtl to cut
sections
Hi Robert
when reading your posting I just got a spontaneous idea - maybe the
light stems from the constant ambient term (-av ...) which gets
activated on every rayhit. Although your boxes are closed, de facto
they're open because of the cutoff-plane, and rays hit inside and will
get assigned the constant ambient term (in the same manner as a scene
with no sources present). Maybe, maybe ..
Carsten
--__--__--
End of Radiance-general Digest
