Strange halo artifact in rendering
Folks,
I am stumped. There is a halo around a black box on a grey background
in a rendering, and I can't figure out how to get rid of it (because I
can't imagine that it's real).
I am preparing renderings for an art submission, and I am simulating a
little model mountain inside a small flat black frame on a light grey
wall, in a room with an array of ceiling lights and one spot. Here is
what happens (rpict and mountain-removed rvu):
The black material is plastic with 0.0 specularity.
The halo is independent of the ambient parameters.
The halo is independent of -lw refinement.
The halo is still there if the black box touches the wall or is offset a little.
The halo doesn't go away when I render at high resolution.
Can anyone tell me what is going on here? Unzip and run "make" on:
http://markjstock.org/transfer/whatGives.zip
Mark
Hi Mark,
I tried to run your example but I failed. Some files seem to be missing.
What about increasing the roughness of your black frame?
Best Kai
  Freundliche Grüße
  Kai Babetzki
  Dipl.-Phys. Kai Babetzki
  Mailto:[email protected] phone: +49-711-67976-288
  http://www.transsolar.com fax: +49-711-67976-11
  Transsolar KlimaEngineering
  Technologien für energieeffizientes Bauen und Nutzerkomfort in Gebäuden
  Strategies for energy efficient design and thermal comfort in buildings
  Stuttgart - München - New York
  Transsolar Energietechnik GmbH
  Curiestrasse 2- 70563 Stuttgart
  Geschäftsführer :
  Diplom-Ingenieur Matthias Schuler, Diplom-Ingenieur Thomas Auer, Diplom-Physiker Stefan Holst
  Eingetragen beim Amtsgericht Stuttgart HRB 23347 USt-IdNr.: 99073/00911
Von: Mark Stock [mailto:[email protected]]
Gesendet: Freitag, 15. März 2013 05:56
An: [email protected]
Betreff: [Radiance-general] Strange halo artifact in rendering
Folks,
I am stumped. There is a halo around a black box on a grey background in a rendering, and I can't figure out how to get rid of it (because I can't imagine that it's real).
I am preparing renderings for an art submission, and I am simulating a little model mountain inside a small flat black frame on a light grey wall, in a room with an array of ceiling lights and one spot. Here is what happens (rpict and mountain-removed rvu):
Mark
Kai,
Thanks for checking. Which files were missing?
Changed black frame to "0.03 0.03 0.03 0.0 0.2" and no change.
Mark
On 3/15/13, Kai Babetzki <[email protected]> wrote:
Hi Mark,
Best Kai
  Freundliche Grüße
  Kai Babetzki
  Geschäftsführer :
Folks,
http://markjstock.org/transfer/whyTheHaloMaster.png
http://markjstock.org/transfer/whyTheHalo.png
little.
Mark
Hey Mark,
What are your parameters? Have you taken a look at -dr, -dc, -dt?
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
channeling technology for superior design and construction
On 3/15/2013 8:46 AM, Mark Stock wrote:
Kai,
Mark
Hi Mark,
Best Kai
  Freundliche Grüße
  Kai Babetzki
  Geschäftsführer :
Folks,
little.
Mark
Sorry I did not mean -dr (thinking of a different thread), so -ds, -dc, -dt...
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
On 3/15/2013 8:48 AM, Jack de Valpine wrote:
Hey Mark,
Jack,
Sorry. Reducing -dc -dt and -ds doesn't seem to do anything.
I learned this morning that the halo is coming from the array of ceiling lights and not the spotlight.
I also discovered that the halo gets smaller as the black box is moved away from the wall.
And the antimatter cutout that turns the box into a frame doesn't affect the halo.
Mark
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
Hey Mark,
Hi Mark,
Yeah, poking around a bit I see the direct parameter don't seem to have much impact. On the other hand I found that if I set -ar to 256 then the halo disappears.
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
On 3/15/2013 9:57 AM, Mark Stock wrote:
Jack,
Mark
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
Hey Mark,
Jack,
Excellent! Thank you. I am surprised that -ar has any effect when sampling is turned off (-aa 0). I didn't even try to modify -ar because I didn't think it would do anything.
Mark
Hi Mark,
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
Jack,
Mark
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
Hey Mark,
That was pretty clear to me, in looking at the rendering. The multiple
edges evident particularly from the bottom of the frame are the giveaway.
You are using Radiance light objects, and these always give these
exceedingly (unbelievably) sharp edges to the pools of light that they
cast. Radiance lights based on a photometry file tend to have softer
edges, even those based on directional lamps.
Jack's trick worked because even tho you have -aa at zero, you have -ab 2
which will still cause the ambient calculation to be run; the increased
-ar has the effect of softening the halo, I think. -aa 0 simply turns off
interpolation, not the ambient calculation altogether.
I think.
That doesn't sit well with me. I do want the ambient calculation, but "-aa 0" is supposed to turn caching off---or run a fresh new hemisphere sampling for every image pixel (assuming -ps 1). So why would it interpolate from some brighter ambient point in the dark area *under the frame* instead of probing outward for the incident light? Ambient resolution should have no part of that.
M
I think.
unless you did already,
try:
-as 0
and -ad as you please
G
On 15 Mar 2013, at 04:56, Mark Stock <[email protected]> wrote:
Folks,
Mark
