hi there
i'm fairly new to the radiance package, and to rendering in
general, but i have a fairly specific project on the go, with
which i need some help.
i am trying to use radiance to render a relatively simple model
geometrically - just a simple room, with a box sitting on the
floor - but with up to 100 or so light sources. but the difference
is that i want to get a separte image file for each light
source - i.e. hundred or so images, with only 1 light on in each.
i will then use superposition and recombine the images later,
allowing me to vary the intensities of each light source.
I hope you are aware of the fact that a incandescent light source
will have a shift of the spectrum in it's output when you change
the intensity (reduce the power for the lamp). But I don't think
you're bothered about this (small) aspect, so let's move on.
is there any kind of built in functionality in radiance to
allow me to do this, or do i have to write a shell script or
something (and if so, can anyone point me towards a good place
to learn how! i come from a very winndows based background)
The "build in functionality" of Radiance is it's simplicity.
Small tools for small tasks. And yes, you will have to write
a script for your problem. But it will be a simple script.
First you have to organize your scene data:
a) everything that is static in the scene in one file
b) a bunch of files containing everything that isn't
(in your case 100 files with the description of 1 light
source each).
c) definitions of i.e. viewpoints or render parameters
The basic steps to create one image are:
1) Compile a scene octree from the static and one dynamic file
2) Render the image with the created octree as input
I don't know much about your light so I assume you have
created a "static.rad" file, 100 "dynamic.001" etc. files
and a file with render options "render.opt".
Creating your images is as simple as:
for i in `seq -w 100`
do
oconv static.rad dynamic.${i} > tmp_scene.oct
rpict @render.opt tmp_scene.oct > image_${i}.pic
done
Not as bad as it sounds, eh?
There is plenty of room for improvements: in particular, you don't
need all the 100 files for light sources if the vary only in
position or in other small details. That could be done within
the "for ..." loop, too. All depends on your needs.
For a simple introduction to bash google for "bash tutorial"
and try a few of the hits. It depends on you what's the right
introduction level. You can use any other scripting language
as well (Python, Perl, TCL) if you already know one.
HTH,
On 14.01.2006, at 16:23, william reynolds wrote:
