scene 0 tutorial error
Hi everyone,
I'm new to Radiance and walking through the "Scene 0" tutorial from
Chapter 1 in the book (also
http://radsite.lbl.gov/radiance/refer/tutorial.html). I only get up to
adding the box for the room before hitting my first error - rebuilding
the octree with the !genbox line gives this error:
invalid command line argument:
gray_paint
I have the gray_paint material defined above in the rad file and
double-check everything. What's going on?
Cramer
J. Cramer Silkworth
Transsolar Climate Engineering
Technical consulting for energy efficiency and environmental quality.
145 Hudson Street
Suite 402
New York, NY 10013
Tel 212 219 2255
Fax 212 219 2256
silkworth@transsolar.com
Hi Cramer,
As far as I can tell, this is not a Radiance-generated error. It must be coming from whatever shell you are using, and may indicate you have some hidden or illegal character in your file. Try deleting and re-entering the line to see if that helps.
What operating system are you using?
From: "Cramer Silkworth" <silkworth@transsolar.com>
Date: June 5, 2008 9:01:54 AM PDT
Hi everyone,
I'm new to Radiance and walking through the "Scene 0" tutorial from Chapter 1 in the book (also http://radsite.lbl.gov/radiance/refer/tutorial.html). I only get up to adding the box for the room before hitting my first error - rebuilding the octree with the !genbox line gives this error:
gray_paint
I have the gray_paint material defined above in the rad file and double-check everything. What's going on?
Cramer
Greg,
I deleted and re-entered the line, to no avail. I'm running Terminal on
Gnome on Ubuntu 8.04, and created & edited the rad file with vi. I
attached the session.
Cramer
typescript.txt (5.24 KB)
[mailto:radiance-general-bounces@radiance-online.org] On Behalf Of Greg
Ward
Sent: Thursday, June 05, 2008 12:09 PM
Subject: Re: [Radiance-general] scene 0 tutorial error
Hi Cramer,
Hi everyone,
gray_paint
Cramer
Hi Cramer,
The "script" program doesn't work with "vi". How about sending me the Radiance input file that's generating the error, instead?
Date: June 5, 2008 9:32:14 AM PDT
Greg,
Cramer
Greg,
Ah, yeah that file is a mess, sorry. Here's the rad file.
-Cramer
room.rad (339 Bytes)
Ward
Sent: Thursday, June 05, 2008 12:44 PM
Hi Cramer,
Greg,
Terminal on
Cramer
Hi Cramer,
There doesn't seem to be anything wrong with your file, and oconv likes it just fine.
I just noticed in your typescript file that the problem is you have a different program also called "genbox" that is being called (from Gromacs) instead of the Radiance tool. The easiest fix is to run "which genbox" to find the path to the other one, then change your PATH order for your shell initialization file to point to the Radiance executable directory before the other one.
I hope this sorts out your problem.
Date: June 5, 2008 9:50:56 AM PDT
Greg,
-Cramer
Ward
Hi Cramer,
Greg,
Terminal on
Cramer
Greg,
That was it. I took me a minute to figure out how to find and edit the
initialization file (editing /home/[username]/.bashrc as root), but it
works now. Thanks!
-Cramer
Ward
Sent: Thursday, June 05, 2008 1:10 PM
Hi Cramer,
likes it just fine.
Greg,
-Cramer
Greg
Ward
Hi Cramer,
Greg,
Terminal on
Cramer
