Hi!
While waiting for an answer to my first message, here is a second question.
I get a strange behaviour when I use rtrace to get irradiance/illuminance
values from sky patches described using the primitive "source" with modifier
"glow". Here is an example:
--------8<--------8<--------8<--------8<--------8<--------8<--------8<--------
#file: patch1.rad = patch located at altitude gamma=30�; theta=90�-30�=60�
void glow skyglow
4 1 1 1 0
skyglow source skypatch
4 0.836516 0.224144 0.500000 11.500000
#file: patch2.rad = patch located at altitude gamma=90�; theta=90�-90�=0�
void glow skyglow
4 1 1 1 0
skyglow source zenith_skypatch
4 0.000000 0.000000 1.000000 11.500000
The solid angles subtended by the patches are equal to 0.0316 steradians in
both cases.
Then I "oconv" the two files to get the octrees (respectively p1.oct and
p2.oct) and I want to get the direct daylight coefficients for the two
patches.
The patch radiance is 1 and the scene is made only by each patch and a
measurement point located at 0 0 0, direction 0 0 1. So ...
$ echo '0 0 0 0 0 1' | rtrace -h -w -I+ -ab 1 p1.oct | rcalc -e \
'$1=$1/0.0316'
0.373048734
ok! in this simple case it should be equal to sin(30)=cos(60)=0.5
so I increase the -ad and -as values:
$ echo '0 0 0 0 0 1' | rtrace -ad 2048 -as 1024 -h -w -I+ -ab 1 \
p1oct | rcalc -e '$1=$1/0.0316'
0.497311709
that is very close to the correct value.
Let's make the same with the second patch (orthogonal to the measurement
point):
$ echo '0 0 0 0 0 1' | rtrace -h -w -I+ -ab 1 p2.oct | rcalc -e \
'$1=$1/0.0316'
1.1191462
uhm ok! let's increase the -ad and -as values:
$echo '0 0 0 0 0 1' | rtrace -ad 2048 -as 1024 -h -w -I+ -ab 1 \
p2.oct | rcalc -e '$1=$1/0.0316'
0.413590506
Hey! What happened?
If I set -as 0 I still get a good value ... is it a trouble with my way of
using it or something wrong with the code?
Should I use some other -a* switch?
Thank you!
Francesco Anselmo
anselmo@dream.unipa.it
