Dear Greg and Chistopher, Thank you very much for your detailed advices! -
Ji
On Tue, Apr 26, 2011 at 11:32 PM, Greg Ward <[email protected]> wrote:
Hello Ji,
I won't address all of your issues, but you seem to be laboring under a
basic misunderstanding regarding image file names and types. Simply
specifying a different suffix doesn't cause Radiance to write out whatever
format file you choose. Rpict and most Radiance tools that don't start with
"ra_" output only to Radiance RGBE (.hdr) format. MacOS X and Photoshop are
smart enough to ignore the suffix and interpret the file correctly, though
they may perform different tone-mapping operations to display them. Hence,
the differences you are seeing.There are no converters to JPEG or PNG image formats included with
Radiance. You can get to BMP, TIFF, GIF, Targa, Pict, PPM, and PostScript.
A typical conversion might go like this:rpict [options] octree > result.hdr
ra_bmp -e auto result.hdr result_tm.bmpI have added "_tm" to the name to indicate that it has been tone-mapped. A
general tool for performing tone-mapping, which outputs to Radiance format
but in a restricted range, is pcond. A similar result to the above in PPM
format may be obtained with:pcond result.hdr | ra_ppm > result_tm.ppm
Any other formats than those listed above will have to be reached using
Photoshop, Photosphere, Preview, or other tools. As I mentioned, they each
have their own notion of tone-mapping, so your mileage may vary.As for the splotches and so forth, there are a plethora of options that
affect rendering quality, and if there is nothing wrong with your model, the
use of "rad" or "trad" is highly recommended to help you set up your
simulation.Best,
-GregP.S. As an interesting side-note, Unix tools do not even see the file
suffix if you use redirection, i.e., "> output_file.sfx". In the Unix
tradition, none of the Radiance tools look at or enforce any particular file
suffix usage, and everything is done by convention for the user's benefit.> From: Ji Zhang <[email protected]>
> Date: April 26, 2011 6:57:11 AM PDT
> Dear Radiance experts,
> I'm testing rendering radiance scene using rpict with Radiance 4.0 in Mac
OS 10.6.7
> Problem A:
> I'm using the following rpict command:
> rpict -vf /test/view.vf -w -aa 0.2 -ab 3 -ad 2048 -ar 128 -as 512 -x
500 -y 500 /test/scene.oct > /Users/oat/Desktop/image.jpg
> However, I have the following problem with the png file generated:
> 1. the surfaces not facing the sun directly looks like being burnt
> 2. there're a lot of black splotches along the edges and corners of the
wall
> 3. the image has a lot of jagged edges
> 4. it cannot be open in photoshop but it can be previewed in Mac OS
> the preview of this png file as screen-captured is like:
https://2omvuw.bay.livefilestore.com/y1p8T69Ib9EOtRETgqUwtZrJ_hfoKx1uDj4hkHKIFICcIAZ17CFilr8bRaY0n6zURTGQpmdYWRALT2rnvmiz3cUmUDR8IG_-xBd/Mac%20OS%20png.png?psid=1
> Problem B:
> If I render the image as .hdr file it still have the same problem 1 to 3
as mentioned above when I preview it in Mac OS. But the hdr image can be
open in Photoshop and appears quite right with less severe splotch problem.
> The rpict command:
500 -y 500 /test/scene.oct > /Users/oat/Desktop/image.hdr
> The hdr image as opened in Photoshop is:
https://2omvuw.bay.livefilestore.com/y1p5J22wHNNnuKciUzj5slOchjNGAKcZ7NclFvCojDvwVmrgoglis8BQt4RB9BTaPLpbk3_3sjaJ11-TSpsM6ndEVuA5FKwZp3Y/Mac%20OS%20hdr.png?psid=1
> Problem C:
> if I add a ground surface into the scene, the hdr image as rendered will
have a lot of bright splotches along the bottom of the wall surfaces (the
ground surface is positioned 0.3m lower than the floor surface of the room):
https://2omvuw.bay.livefilestore.com/y1perNd2uKYSrsH2hXoIZqyVynQkw1Eid2ULgDb-gY3VJ-Cb9ANIhZ1ZucPz7rZQynAypp_Fjskp1gN9pbgNneAp7A7Hbxzwa0B/Mac%20Os%20hdr%20_with_ground.png?psid=1
> The maximum dimension of the scene is around 100m after adding the ground
surface.
> I'd like to ask:
> 1. why the png or jpg file generated using rpict in Mac OS can be
previewed but cannot be open in Photoshop?
> 2. why the png, jpg or hdr image generated using rpict in Mac OS looks
"burnt out" when previewed?
> 3. why only the hdr image file can be opened in Photoshop and appears
normal?
> 4. why does the additional ground surface cause the splotches? and how to
correct it?
> 5. how to get a clean hdr image with smooth surfaces that have no
splotches and jagged edges?
> 6. What are the key rpict parameters to control the image quality?
> Can you kindly help to take a look and advise me the source of problem
and the solutions?
> Thank you!
> Ji_______________________________________________
Radiance-general mailing list
[email protected]
http://www.radiance-online.org/mailman/listinfo/radiance-general
