Hi Vaib,
You could also try using an "illum" in place of a "light."
Jack de Valpine
President
Visarc Incorporated
www.visarc.com
channeling technology for superior design and construction
On 2/17/2014 9:15 AM, Thomas Bleicher wrote:
Vaib
I think the -dv switch works as designed. It will not hide the light source completely but the source itself is shown in black instead of the actual brightness that the object (lamp, light fitting etc) would have. I think that was done to avoid high intensity peaks that would confuse certain evaluation algorithms in other applications.
In your case you should be able to hide the light sources using a clipping plane. Check the -vo option of rpict.
ThomasOn Sun, Feb 16, 2014 at 5:19 PM, Vaib <vaibhavjain.co@gmail.com > <mailto:vaibhavjain.co@gmail.com>> wrote:
Hello everyone,
I tried to make light source invisible by using the -dv option in
rpict, but somehow it doesn't work for me. The lights are shown black.In my case, the camera and lights are placed at the same height in
a room, and the camera is looking down towards the floor. I have
tried both with and without -dv option.When I place camera just below the lights, then the lights are not
visible (which is obvious, as lights are then not in line of sight).Has someone else also experienced the same? Thank you!
Best regards,
Vaib_______________________________________________
<mailto:Radiance-general@radiance-online.org>
http://www.radiance-online.org/mailman/listinfo/radiance-general_______________________________________________
