rpict: color channel separation
Dear list members:
While getting acquainted with radiance, I stumbled on a phenomenon
that I do not understand.
I keep the following scene description (of a red sphere lonely in vast Euclidean space) in a file called sphere_0.rad
void light SphereLight_0
0 0 3 0.000431188 0 0
SphereLight_0 sphere sphere_0
0 0 4 0 500 0 100
I use oconv and rpict to render the scene and check the output using pvalue.
oconv sphere_0.rad > o.conv
rpict -x 128 -y 128 o.conv | pvalue -o -h -u
The first few lines of output of these commands are
-Y 128 +X 128
     60 95 4.320e-04 9.537e-07 9.537e-07
     62 95 0.000e+00 0.000e+00 0.000e+00
     63 95 4.320e-04 9.537e-07 9.537e-07
     65 95 0.000e+00 0.000e+00 0.000e+00
     67 95 4.320e-04 9.537e-07 9.537e-07
     68 95 0.000e+00 0.000e+00 0.000e+00
     56 94 4.320e-04 9.537e-07 9.537e-07
They demonstrate that am picking up some small power contributions in
the g and b channel which seem suspicious to me. When I use rtrace in an
attempt to reproduce the phenomemon, I find 0 for g and b as I'd expect.
I'd be grateful if somebody could share her/his insight
ps - random observations:
- I have experimented with program options, but even though the defaults
of rtrace and rpict differ slightly, they seem to not be able to explain
rpict's behavior
- A colleague at Fraunhofer ISE checked the pic-file and mentioned to
me that the non-zero contributions are present in the rpict output and
are not created later by pvalue
Stefan Schwarzer
Fraunhofer-Institut für Physikalische Messtechnik IPM
Optische Fertigungsmesstechnik
Heidenhofstr. 8, 79110 Freiburg, Germany
Telefon: +49-(0)761-8857-366
Ist Ihr Browser Vista-kompatibel? Jetzt die neuesten
Browser-Versionen downloaden: http://www.gmx.net/de/go/browser
Hello Stefan,
This is simply the round-off error associated with the Radiance RGBE format. Since the picture format uses three mantissas with a common exponent, it is not possible to represent a non-zero value in one channel and a zero value in another channel. Even though the actual byte stored for green and blue may be zero in your calculation, the decoder will interpret this as half a count out of 255 and give a corresponding value.
Since the main purpose of Radiance is lighting calculations for visual simulation, and the eye's color channels have a (more or less) linear response, this is an appropriate/adequate representations for the design application. If you need the original floating point values, and don't mind files than are about 5 times bigger, you can use vwrays with rtrace and output floating point images directly.
I hope this helps.
Date: February 18, 2008 2:56:05 AM PST
Dear list members:
0 0 4 0 500 0 100
-Y 128 +X 128
rpict's behavior
Stefan Schwarzer
