Dear Radiance experts,
I'm new to Radiance and appreciate if you can help me on this simple
question:
The following commend in the Shell of Unix will get the horizontal
irradiance value due to the uniform sky as defined in the sky_uni.oct file:
% echo "0 0 0 0 0 1" | rtrace -h -r+ -w -ab 1 sky_uni.oct
May I ask in order to do the same thing what DOS commands I should use do
the same thing in the command window of a Windows XP or Vista system when
I'm using the Desktop Radiance?
Thank you!
Ji
