I sent this message earlier - but I think it may have gotten lost. I
apologize if you receive it twice!
Has anyone an example of how to write a .cal function for plasfunc,
for a given BRDF?
Specifically, I am not sure which predefined variables correspond to
the view direction vector.
This is the BRDF I want to use in Radiance:
V(i,j,n,a)=(1/PI)*(a/(a+(i dot n)(j dot n))
:i is unit vector from the source direction, j is unit vector of view
direction, n is surface normal, a some other parameter.
I know the Radiance-predefined variable names for the source direction
(x,y,z) and surface normal (Nx,Ny,Nz), but I am not sure what to use
for the view direction.
Can anyone help?
Thank you!
katja
Hi Katja ---
Here's the hack I use. Pass the viewpoint as arguments to the .cal function. Then view direction is just:
Vx = -(arg(1) - Px);
Vy = -(arg(2) - Py);
Vz = -(arg(3) - Pz);
where Px, Py and Pz are the Radiance predefined variable names for the ray intersection points.
Hope this helps,
Roland
for a given BRDF?
Can anyone help?
Thank you!
katja
r o l a n d f l e m i n g p h d
r e s e a r c h s c i e n t i s t
m a x p l a n c k i n s t i t u t e f o r b i o l o g i c a l c y b e r n e t i c s
s p e m a n n s t r . 3 8
7 2 0 7 6 t u e b i n g e n
g e r m a n y
t e l :: [ + 4 9 ] 0 7 0 7 1 6 0 1 - 6 0 9
On Jul 18, 2005, at 5:26 PM, Katja Doerschner wrote:
Hi ,
you might have a look at the header section of the file 'rayinit.cal', here all predefined variables can be found..
The general ray direction e.g is Dx, Dy, Dz (which of course correponds to the view direction for the primary view rays.)
-cb
Thanks. Yes, I did look at rayinit.cal- that is were I found the other
variables. Now I used DxDyDz as my view direction vector and my .cal
function seems to work. (Well, technically that is).
katja
----- Original Message -----
Date: Monday, July 18, 2005 9:43 pm
Subject: Re: [Radiance-general] rewrite BRDF as .cal file for plasfunc
Hi ,
'rayinit.cal',
correponds
-cb
Hi Roland,
I just tried out your suggestion after getting funny results with the
DxDyDz as view direction. Your 'hack' works perfectly!!!!! Thanks a lot.
katja
From: Roland William Fleming <roland.fleming@tuebingen.mpg.de>
Date: Monday, July 18, 2005 11:44 am
Hi Katja ---
the
Hope this helps,
Roland
lost. I
> Hello,
> for a given BRDF?
what to use
> Can anyone help?
> Thank you!
> katja
l
g e r m a n y
I think that Dx, Dy, Dz correspond to the direction vector of the ray which is different than the direction vector of the view. So this may account for some of your funny results.
Hi Roland,
katja
Hi Katja ---
Hope this helps,
Roland
lost. I
for a given BRDF?
what to use
Can anyone help?
Thank you!
katja
g e r m a n y
# John E. de Valpine
