Rendering parameters help and weird colors
Dear List,
So I have been rendering with some interesting features in SketchUp, like
exporting landscapes (hills and mountains) from GoogleEarth.
Here is a link for you to understand what I am talking
about<https://www.dropbox.com/sh/ltv125db6hjp74a/hsnL6S-_JI>
Anyway, I have been rendering some stuff and I have two doubts:
1.- My environment is basically grey, but only the mountain near my
building is brown; but everything has turned to be brown (as can be seen in
Image2)... is that the "color bleeding" (or something like that)? Is that a
good result? or there is a problem with my modeling?
2.- As can be seen in Image (the one that shows the interior of the
building, looking out), there are some weird effects, making my image to
look as it was painted with a brush or something. What is the parameter
that would help me reduce that?
I am not sure why in Dropbox the images look much more darker than in my
PC. They were created using rpict, and then filtered with "pfilt -x /2 -y
/2 image.hdr > image.tiff"
THANKS VERY MUCH
German
Hey German,
For sure it looks like there is some color bleeding, and also the fact that you have modeled the entire mountain — making your model extents fairly large relative to the area of interest (your building interior) is likely causing you some pain here too. It would be helpful to see your material definitions, and also your rendering parameters (particularly the ambient (-a*) ones).
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 4/17/13 10:12 AM, "Germán Molina Larrain" <[email protected]<mailto:[email protected]>> wrote:
Dear List,
So I have been rendering with some interesting features in SketchUp, like exporting landscapes (hills and mountains) from GoogleEarth.
Here is a link for you to understand what I am talking about<https://www.dropbox.com/sh/ltv125db6hjp74a/hsnL6S-_JI>
1.- My environment is basically grey, but only the mountain near my building is brown; but everything has turned to be brown (as can be seen in Image2)... is that the "color bleeding" (or something like that)? Is that a good result? or there is a problem with my modeling?
2.- As can be seen in Image (the one that shows the interior of the building, looking out), there are some weird effects, making my image to look as it was painted with a brush or something. What is the parameter that would help me reduce that?
I am not sure why in Dropbox the images look much more darker than in my PC. They were created using rpict, and then filtered with "pfilt -x /2 -y /2 image.hdr > image.tiff"
THANKS VERY MUCH
German
Hi Robert,
My material definition was the following (I assume it is easy to notice
what is what)
void glass SL_glass
3 .92 .92 .92
void plastic GroundMat
5 0.435 0.306 0.216 .00 0.06
void brightfunc floorpat
2 .4*rand(floor(Px/.25)-.25*floor(Py/.25)-.25)+.6 .
floorpat plastic Floor
5
    .3 .3 .3 0 0
void plastic SL_default_material #(basically every wall and ceiling)
5 .7 .7 .7 0 .01
My ambient parameters were (the rest are all defaults):
-ab 8 -ad 2000 -aa 0.05 -ar 256
THANKS VERY MUCH
German
2013/4/17 Guglielmetti, Robert <[email protected]>
Hey German,
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 4/17/13 10:12 AM, "Germán Molina Larrain" <[email protected]<mailto: > [email protected]>> wrote:
Dear List,
THANKS VERY MUCH
German
On the other hand, the reason I modeled the mountain is to actually
consider the shading it provides (that is the area I am working on)... so I
think just eliminate it would not be the solution.
Is color bleeding a problem that "would occur in real life"?? I mean, is a
modeling problem (clearly the mountain is not completely brown), or a weird
effect of the algorithms involved?
THANKS AGAIN!
German
2013/4/17 Germán Molina Larrain <[email protected]>
Hi Robert,
what is what)
void glass SL_glass
3 .92 .92 .92
5
    .3 .3 .3 0 0
5 .7 .7 .7 0 .01
THANKS VERY MUCH
German
Hey German,
Rob Guglielmetti
Golden, CO 80401
303.275.4319
On 4/17/13 10:12 AM, "Germán Molina Larrain" <[email protected]<mailto: >> [email protected]>> wrote:
Dear List,
THANKS VERY MUCH
German
It does look like there's quite a bit of color bleeding, and the thin stripe of sunlight on the floor makes for difficult sampling as well. You would be much better off treating your window as an illum in this case using mkillum. You can follow the tutorial example at the end of chapter 1 if you're not sure how to do this:
  http://radsite.lbl.gov/radiance/book/ch1/ch1.pdf
Date: April 17, 2013 9:12:02 AM PDT
Dear List,
THANKS VERY MUCH
German
Hi German,
I understand, but the problem with modeling far-reaching terrain is that the spacing between your ambient sampling points blows up quite a bit. What I generally recommend is that you substitute the actual mountain with proxy geometry closer to the building (say, within 100' of the building perimeter) that represents the shading effect of the distant ground. In other words, project the mountain onto flat polygons closer to the scene-
...and Greg just chimed in with a better answer. =)
From: Germán Molina Larrain [mailto:[email protected]]
Sent: Wednesday, April 17, 2013 10:35 AM
Subject: Re: [Radiance-general] Rendering parameters help and weird colors
On the other hand, the reason I modeled the mountain is to actually consider the shading it provides (that is the area I am working on)... so I think just eliminate it would not be the solution.
Is color bleeding a problem that "would occur in real life"?? I mean, is a modeling problem (clearly the mountain is not completely brown), or a weird effect of the algorithms involved?
THANKS AGAIN!
German
2013/4/17 Germán Molina Larrain <[email protected]<mailto:[email protected]>>
Hi Robert,
My material definition was the following (I assume it is easy to notice what is what)
void glass SL_glass
3 .92 .92 .92
5
    .3 .3 .3 0 0
5 .7 .7 .7 0 .01
THANKS VERY MUCH
German
2013/4/17 Guglielmetti, Robert <[email protected]<mailto:[email protected]>>
Hey German,
For sure it looks like there is some color bleeding, and also the fact that you have modeled the entire mountain - making your model extents fairly large relative to the area of interest (your building interior) is likely causing you some pain here too. It would be helpful to see your material definitions, and also your rendering parameters (particularly the ambient (-a*) ones).
Rob Guglielmetti
Golden, CO 80401
303.275.4319<tel:303.275.4319>
On 4/17/13 10:12 AM, "Germán Molina Larrain" <[email protected]<mailto:[email protected]><mailto:[email protected]<mailto:[email protected]>>> wrote:
Dear List,
THANKS VERY MUCH
German
Color bleeding certainly happens in real life, but most mountains are not this orange on average. You have modeled an unusual condition, and might be better moving it to a more neutral color. Also, many cameras perform automatic white balance, which Radiance does not do for you.
Date: April 17, 2013 9:35:28 AM PDT
THANKS AGAIN!
German
Hi Robert,
void glass SL_glass
3 .92 .92 .92
5
    .3 .3 .3 0 0
5 .7 .7 .7 0 .01
THANKS VERY MUCH
German
Hey German,
Rob Guglielmetti
Golden, CO 80401
303.275.4319
Dear List,
THANKS VERY MUCH
German
Because the size of your exterior site geometry is so large compared to your room, you could increase -ar. There's a formula to calculate a good value, which I think is part of what the rad command does if the scene dimensions are set smaller than your whole octree. If your rendering doesn't take too long you could just try increasing it arbitrarily, maybe jump up to 1000 to look for any benefit. You could also try setting -as around 500 instead of the default 128.
Those are the quick and easy things to try, but the recommendations from Rob and Greg might be even better or faster.
Well, thanks guys! I will try making the -ar bigger, and illum. Is just, I
think that, on the Rendering with Radiance Book, John Mardaljevic mentions
that for daylighting it is not recommended to use Illums.
Anyway... I will use more neutral colors, illums and a higher ambient
resolution as a learning exercise.
*Would this same model cause problems when using the Three-phase method?*
THANKS VERY MUCH
German
German
2013/4/17 Christopher Rush <[email protected]>
your room, you could increase –ar. There’s a formula to calculate a good
doesn’t take too long you could just try increasing it arbitrarily, maybe
jump up to 1000 to look for any benefit. You could also try setting –as
around 500 instead of the default 128.****
Rob and Greg might be even better or faster.****
*From:* Germán Molina Larrain [mailto:[email protected]]
My ambient parameters were (the rest are all defaults):****
-ab 8 -ad 2000 -aa 0.05 -ar 256****
