Rendering of Gensky
I am using gensky ( Code given below) to illuminate an outdooe scene. Camera is looking upward.
When i render the scene using rpict into hdr. Why I am able to see the sun but not sky ? I comes out to be black.
# gensky 3 7 10:30CET +s -a 57.013056 -o -9.988333
# Local solar time: 9.98
# Solar altitude and azimuth: 22.4 -32.9
# Ground ambient level: 11.1
void light solar
3 5.49e+06 5.49e+06 5.49e+06
solar source sun
4 0.502204 -0.776482 0.380614 0.5
void brightfunc skyfunc
2 skybr skybright.cal
7 1 5.04e+00 1.02e+01 3.47e-01 0.502204 -0.776482 0.380614
Best Regards, Brajesh Lal
is looking upward.
Gensky only produces the distribution function for the sky but nothing
it is applied to. The "sun" is created as a source but not the sky
dome (see below).
These lines are just comments with useful stuff about the sky. The do
not contribute to the scene.
void light solar
solar source sun
These two groups define a 'light material' called 'solar' and apply
this material to the geometry type 'source' to produce the 'sun'.
As above this group defines a material that describes the light
distribution over the sky dome. What's missing is a geometry it can be
applied to. I assume you have used gensky on the command line and
saved the output to a file. Add the following lines at the end of the
file:
# basic glow material for sky; brightness is defined by 'skyfunc'
skyfunc glow skyglow
4 1 1 1 0
# sky dome: 'source' type with skyglow material covering upper hemisphere
skyglow source sky
4 0 0 1 180
# material for ground; use same brightness function but reduced to 10 percent
skyfunc glow groundglow
4 0.1 0.1 0.1 0
# apply 'groundglow' to source covering the lower hemisphere
groundglow source ground
4 0 0 -1 180
# end of sky and ground description
On Sat, Mar 13, 2010 at 5:11 PM, Brajesh Lal <brajeshlal@yahoo.com> wrote:
