Hi Greg and Rob,
Thanks Greg. I did a test and it works like a charm for perspective views.
I haven't tested it for other types of views yet.
Rob, rpiece is not actually included in the recent Windows packages. I have
it there from an old release! Oops...
Let me know when you are back so we can check the results. It works perfect
on my side. Maybe I should test more cases.
Mostapha
路路路
On Fri, Aug 1, 2014 at 4:52 PM, Rob Guglielmetti <rob.guglielmetti@gmail.com > wrote:
Hey Mo, I can share my results with you on this when I get back from
vacation; I made a spreadsheet to calculate the views based on that code
but as I recall I got some funky results.Also thanks for the heads up on rpiece in the windows packages, I'll make
sure that's not included in the future! Oops...On Jul 31, 2014, at 11:59 PM, Greg Ward <gregoryjward@gmail.com> wrote:
It's possible, but not at all straightforward. You basically have to use
the attached code (taken from rpiece) to adjust the -vh and -vv options to
rpict, then use the -vs and -vl options to determine which part of the
picture you want to render.Best,
-Gregswitch (ourview.type) {
case VT_PER:
pview.horiz = (2.*180./PI)*atan(
tan((PI/180./2.)*ourview.horiz)/hmult );
pview.vert = (2.*180./PI)*atan(
tan((PI/180./2.)*ourview.vert)/vmult );
break;
case VT_PAR:
case VT_ANG:
pview.horiz = ourview.horiz / hmult;
pview.vert = ourview.vert / vmult;
break;
case VT_CYL:
break;
case VT_HEM:
pview.horiz = (2.*180./PI)*asin(
sin((PI/180./2.)*ourview.horiz)/hmult );
pview.vert = (2.*180./PI)*asin(
sin((PI/180./2.)*ourview.vert)/vmult );
break;
case VT_PLS:
pview.horiz = sin((PI/180./2.)*ourview.horiz) /
(1.0 + cos((PI/180./2.)*ourview.horiz)) / hmult;
pview.horiz *= pview.horiz;
pview.horiz = (2.*180./PI)*acos((1. - pview.horiz) /
(1. + pview.horiz));
pview.vert = sin((PI/180./2.)*ourview.vert) /
(1.0 + cos((PI/180./2.)*ourview.vert)) / vmult;
pview.vert *= pview.vert;
pview.vert = (2.*180./PI)*acos((1. - pview.vert) /
(1. + pview.vert));
break;
default:
fprintf(stderr, "%s: unknown view type '-vt%c'\n",
progname, ourview.type);
exit(cleanup(1));
}*From: *Mostapha Sadeghipour <sadeghipour@gmail.com>
*Subject: *Re: [Radiance-general] Rendering a single image with
multiprocessor in Windows*Date: *July 31, 2014 2:43:17 PM PDT
I just read that rpiece is not supposed to be part of the Windows
package for some reason so I probably should change the question to is it
possible to render a segment of a view based on -X -Y pixels?I can take care of running them in parallel and putting them back together
separately.Thanks,
MostaphaOn Thu, Jul 31, 2014 at 4:28 PM, Mostapha Sadeghipour < > sadeghipour@gmail.com> wrote:
I wonder is anyone has successfully rendered a single image in parallel
using rpict -PP and/or rpiece in Windows.I have a hard time to understand both the process and the syntax.
Mostapha_______________________________________________
http://www.radiance-online.org/mailman/listinfo/radiance-general_______________________________________________
