Relative path
Does Radiance recognizes the use of "../" to indicate an upper-level
directory when referencing a file?
Thanks a lot
Hani
Hani
I think it does but you still need the leading "." in your RAYPATH
environment variable or the ".." will not be relative to your current
directory. Can't test right now, though.
Actually, an path beginning with '.' or '/' is taken as explicit, so no need for '.' in your RAYPATH search variable.
Date: December 16, 2013 10:46:07 AM PST
Hani
I think it does but you still need the leading "." in your RAYPATH environment variable or the ".." will not be relative to your current directory. Can't test right now, though.
Date: December 16, 2013 9:56:00 AM PST
Does Radiance recognizes the use of "../" to indicate an upper-level directory when referencing a file?
Thanks a lot
Hani
