real time
There are several utilities in radiance to achieve interativity with radiance(rview, rholo...) but all of them are based in sofware, so they are a bit slow, is there any way in which radiance can make use of hardware acceleration? or could be it possible in future? can opengl help to it?...
Ignacio Munárriz,
Escuela de Arquitectura, Universidad de Navarra
Pta:Now i have a "rendering with radiance" ebook version and i am happy!!!! , thanks Greg
Today's hardware acceleration is polygon based. Every geometry is tesselated into triangles and feed more or less optimized into a "geometry pipeline" that is made up of specialied hardware transforming the 3d triangles to 2d screen triangles, removing hidden surfaces and painting the triangles (shading and texturing). The interface specs of the entry point into the pipeline are defined by OpenGL. Only very rudimentary lighting (termed shadow free "local" lighting with a simple surface model) is done at the hardware level. It could be useful in the Radiance context for either speeding up basic drawing functions or as a pure (non-physical lit) geometry display engine.
Open-GL is used by rholo to speed up "painting" of triangles and by "rshow" for displaying the geometry. I found the latter one useful for interactive display (thats why I wrote it) , but I'm still not donating enough time to port it to the new internal libs of R3.5, so a fresh version is not yet ready.
There are some ideas around as to map pre-calculated lighting "levels" onto polygons and then feed them though the pipeline at interactive rates, and there are questions as to whether stick to the geometry (rshow like) or a "scene cube" (rholo like) or an intelligent (read "fast") mix of the two. Greg had some pretty good ideas about this in mind years ago, which never really materialized in projects so far. (as far as I'm aware).
-Peter
forgot to mention on my first reply: http://www.pab-opto.de/progs/rshow/rshow.html has some links (at the end of the page) to papers from 1999 (from my ISE time) describing some ideas about rshow in the architectural context.
-Peter
