RE : RE : how to use pfilt to perform anti-aliasing
you are right!
De : Ji Zhang [[email protected]]
Date d'envoi : mardi, 14. juin 2011 13:16
À : Radiance general discussion
Objet : Re: [Radiance-general] RE : how to use pfilt to perform anti-aliasing
Dear Raphael,
Thanks for your prompt reply and advice!
Does this mean that I may need to bear in mind that the size of the image to be produced by rpict should always be 3 times bigger than the size of the final image I want?
Cheers, Ji
2011/6/14 Compagnon Raphaël <[email protected]<mailto:[email protected]>>
Hi
To perform anti-aliasing you need to reduce your final image size (typically by a factor 3).
Hence your pfilt comand should be:
pfilt -x /3 -y /3 -e 1 -r 0.55 ./direct_sunlight.hdr > test.hdr
Raphael
De : Ji Zhang [[email protected]<mailto:[email protected]>]
Date d'envoi : mardi, 14. juin 2011 08:36
Objet : [Radiance-general] how to use pfilt to perform anti-aliasing
Dear Radiance experts,
I use pfilt to treat a .hdr image generated by rpict command.
However, the the pfilt doesn't seem to have any impact in terms of anti-aliasing of the image.
The pfilt command I used is:
pfilt -x 1024 -y 1024 -e 1 -r 0.55 ./direct_sunlight.hdr > test.hdr
the original .hdr image (saved as png file) is:
the output .hdr of the pfilt (saved as png file) is:
Can you kindly tell me if I'm using pfilt correctly to perform anti-aliasing?
Thanks!
Ji
