RE : Light Shelf Reflections
If all these surfaces are mirrors, then you cannot see anything.... unless:
- there is a non-mirror reflecting object somewhere in your scene that is supoposed to be lit by the multiple-reflecting light path; since it will reflect light in many directions you should see it!
or
- your point of view is located somewhere on the multiple-reflecting light path and your view direction points towards it. Then you should directly see the light source appearing as an image on the last mirror.
Raphaël
De : Shamim Javed [[email protected]]
Date d'envoi : lundi 11 mars 2013 15:56
À : Radiance general discussion
Objet : Re: [Radiance-general] Light Shelf Reflections
I am hoping to see multiple reflections of the light beam reflected off the light shelf top surface in both the floor and the ceiling (all of which are mirror surfaces).
On Mon, Mar 11, 2013 at 10:40 AM, Jack de Valpine <[email protected]<mailto:[email protected]>> wrote:
Hi Shamim,
What changes are you expecting to see?
Jack de Valpine
President
Visarc Incorporated
www.visarc.com<http://www.visarc.com>
channeling technology for superior design and construction
On 3/11/2013 10:03 AM, Shamim Javed wrote:
I am using Radiance via Ecotect. I have played around with changing the values for -dr, -av and -ab without seeing any change in the image output.
On Mon, Mar 11, 2013 at 9:20 AM, Christopher Rush <[email protected]<mailto:[email protected]>> wrote:
Are you using the default parameters for rpict/rtrace? Have you tried setting the -dr parameter greater than 2? If you post the command you are using to calculate the reflections, it may be easier to comment. I suspect it will be more complicated than the -dr setting, but that's a start.
I have been unsuccessful, so far, to generate more than two reflections.
________________________________________________________
