RE : Color Temperature
Hi
It may be possible to estimate the color temperature from the RGB Radiance channels by:
1) transforming the RGB values into xyz trilinear coordinates
2) using an approximate formula relating xyz to color temperature.
See for instance this paper:
McCamy, Calvin S. (April 1992). "Correlated color temperature as an explicit function of chromaticity coordinates". Color Research & Application 17 (2): 142-144
http://dx.doi.org/10.1002/col.5080170211
Hope this will help you.
Raphael Compagnon
-------- Message d'origine--------
De: [email protected] de la part de Nick Calcagni
Date: mer. 02/04/2008 06:57
À: [email protected]
Objet : [Radiance-general] Color Temperature
My first post.... let's hope this works:
Is it possible for color temperature to be measured within Desktop Radiance?
The luminaire color temperature output can be adjusted, but can color
temperature be measured on the surface at a single point in Radiance?
Thank you,
Nick Calcagni
Drexel University
