Random numbers / -DMC
additionally to the general posting a few seconds ago: Reflections off specular surfaces showing patterns. - my two thoughts:
The visible patterns result from correlation between the sequence used in stratifying random numbers and the image width.
Either the stratification's sequence is enhanced (two orders of magn. longer ?) or substituted by something without a sequence.
Or (and more likely) the sequence is de-correlated with image width. A sequence in one line is ok, a sequence slightly one or two pixels off each line is (of course) visible.
-Peter
The correlation with pixel position is intentional. Low-discrepancy
sequences necessarily have some correlation, and it is up to the
programmer to decide how this manifests itself. If you don't choose
something, you are likely to be surprised and disappointed with the
results, as I was initially. I selected this pattern based on its
"brushed" appearance. There is a function (pixnumber?) in src/rt/rpict.c
that determines this, and you are welcome to play around with it.
Quoting Peter Apian-Bennewitz <[email protected]>:
-Peter
So what we really need would be some 2-dimensional random number
generator producing a less conspicuous screening pattern?
Assuming that such a thing even exists, of course...
-schorsch
