Radiance within Mac OSX
hi, all~
i am a beginner to radiance as well as this mailing list. i got a problem that radiance cant work in my mac (OSX 10.6).
i have already installed it, and can run some simple command such as, ra_tiff. but everytime i run the command "rview", the compiler will complain that ""dyld: rview can't open library: /usr/X11R6/lib/libX11.6.dylib (No such file or directory, errno = 2)Trace/BPT trap""
but i am sure i have X11 support in my mac. so how can i do to let it work???
looking forward to your reply~~~many thanks~~~
P.S>i am sorry about any unconvenient due to my POOR english.
������� MSN Explorer: http://explorer.msn.com/lccn/
Hi!
Are you sure ? AFAIK the latest OS X is 10.3.6, is this the one you use? I guess you use the precompiled release? I have 3.6 compiled on 10.3 here, and everything is fine. Do you want to try my binaries for 10.3.x?
Probably, if you use 10.3.x (did you use any other X11-apps in the past?).
I think I am the one writing the worst English on this list - and you didn't have to HEAR me so far :wink:
CU Lars.
Thanks for reply.
the OS i used is OSX 10.3.6.
i use the precompiled release just as u said.
i installed the same version on Linux, and it works well.
in fact, i have no idea about the X11, but i installed the X11 support for mac before install radiance.
i am not quiet sure about wether i put the library file into a correct location.
could u plz send me a copy of your binaries for 10.3.x, and teach me how to get it work step by step? PLzzzzz.
if it could work in my loptop, i dont have to go to the lab everyday....:frowning:
CU Lars.
免费下载 MSN Explorer: http://explorer.msn.com/lccn/
Thanks for reply.
CU Lars.
~{Cb7QOBTX~} MSN Explorer: http://explorer.msn.com/lccn/
On Nov 28, 2004, at 2:42 PM, Shu Chunxiao wrote:
Because of a conflict, the command "rview" has been renamed "rvu"
Try the new name and see if it works.
Matthew
On Nov 27, 2004, at 7:38 PM, ~{Jf~} ~{4:O~~} wrote:
hi, all~~
looking forward to your reply~~~~~~many thanks~~~~~~
Hi!
That's true, however, if this was the problem, he should simply get the wrong program (vi) started, no such error message.
By the way, did you check if this library exists on your system? Try: ls /usr/X11R6/lib/libX11.6.*
The file is there on my OS X 10.3.6 machine and should be installed if you have X11-support!
One more hint, you can perfectly remote-control linux- and other ix-machines from your OS X laptop using ssh, even X11-windows can be redirected to your laptop. IMHO it's better to use "real" computers for large renderings, I don't like to overheat my laptop by having 100% cpu for hours...
I will make some 3.6 binaries and provide them on my binary-pages as soon as I find the time.
CU Lars.
