[Radiance general] MacosX and X11
if someone is interested in using x11 as graphical output for the built in panther terminal this is what is required:
1) launch x11, launch terminal (keep X11 always open when the terminal is open, otherwise it doesn't work!)
2) edit your .bash_profile as follows, just add these lines:
if [ -z "${DISPLAY}" ];then echo -n
export DISPLAY=':0'
fi
3) now open a new terminal window and try ximage, /usr/x11r6/bin/glxgears or others....
should be ok.
cheers,
giulio
I have already posted this stuff, but I forgot to give the most important information.....
the point one: open X11 before using it! ... sorry about that...
fot the people using tcsh (jaguar):
in:
etc/csh.login
add this:
setenv DISPLAY localhost:0 ; setenv DYLD_LIBRARY_PATH
open X11 an then use the terminal to lauch graphical stuff
cheers,
giulio
