Radiance-general Digest, Vol 86, Issue 5
thanks one and all....
really apprecaite the help...
il follow the instructions and get back to all soon...
thanks once again
dhaRam
On Mon, Apr 11, 2011 at 12:30 AM, < [email protected]> wrote:
Today's Topics:
  1. ecotect to radiance simulation (dharam)
  2. Re: ecotect to radiance simulation (Lars O. Grobe)
  3. Re: ecotect to radiance simulation (Ignacio Fajardo)
Message: 1
Date: Sun, 10 Apr 2011 12:52:07 +0530
To: <[email protected]>
Subject: [Radiance-general] ecotect to radiance simulation
Hi there..
Im masters student from India doing my dissertation on the topic: analysis
of Indian traditional trellis (Jali) for daylighting
My question is...
1. i have done modelling in ecotect and the same im exporting to radiance
for daylighting results...
Im very new to the software... i need guidance on how to get proper views
and information regarding the model.
I also want to know hoe to map down results from radiance so for different
cases il have to compare.
2. i have to give the material of sandstone to my model... the whole model
material is sandstone ..but i don find sandstone as a material in ecotect.
Instead its in a layer...so what procedure i have to follow for that or is
there a method for direct application of the material.
thanks
If any tutorial or anyone could guide me....
dhaRam
URL: <
http://www.radiance-online.org/pipermail/radiance-general/attachments/20110410/2e4c3234/attachment-0001.html
Message: 2
Date: Sun, 10 Apr 2011 11:30:31 +0300
Subject: Re: [Radiance-general] ecotect to radiance simulation
Hi, and welcome!
different cases il have to compare.
What are the metrics you want to compare? Are you looking for point-alike
illuminance (as sensor readings), hours where certain criteria are met,...?
Are you going with measured climate data or with come CIE skies?
model material is sandstone ..but i don find sandstone as a material in
ecotect. Instead its in a layer...so what procedure i have to follow for
that or is there a method for direct application of the material.
It would be nice to have some samples measured using a spectrometer. As you
probably only need gray levels for your application, comparing a gray chart
with known reflectances to your samples should be enough. It may also be
interesting to get an idea on how much reflectance varies for the sandstone
found and used in the region. Probably a purely diffuse plastic material can
then represent the material in your model.
Dipl.-Ing. Architect Lars O. Grobe
URL: <
http://www.radiance-online.org/pipermail/radiance-general/attachments/20110410/2140d2f8/attachment-0001.html
Message: 3
Date: Sun, 10 Apr 2011 12:18:49 -0400
Hi dhaRam
We do a lot of daylight simulations in Ecotect - Radiance - Daysim for
external consultant
and personal I have done a master, the professor at the university they
don?t teach all that you need to know about
the software and the data.
You need to export the model from Eco to Radiance, and you have two
options.
But before to do that you need to give in Eco the reflections value of the
material - material properties and colour.
For Sandstone i recomend to find the coeficient of reflection + the colour
of the material, is important that kind of data for the simulation.
To export is high recommend to be sure the path of radiance.
You need cameras in Eco to see the 3D inside render in radiance.
The first option to export is from CP Radiance (last window). CP open a new
control panel, be sure that the options selected in Eco are the same
in CP Radiance, and the click render. This data is very usefull to Daysim.
The other options is called Final Render, this options give the possibility
to export Rad data to Eco analysis grid.
To export the data is very simple because Eco show an alarm of new data to
export when radiance had finished.
You can download powerfull information from the page of Harvard University,
Diego Ibarra from Chile shows on PDF importants tips.
Best Regards
2011/4/10 dharam <[email protected]>
> Hi there..
analysis
> My question is...
different
model
ecotect.
is
> thanks
> dhaRam
> [email protected]
       Jorge Ignacio Fajardo F-A
                  Arquitecto *MDCS*
iBSA - Ingenier?a Blanda S.A
USGBC Member
Jean Mermoz 12, of. D
Of.: (562) 934.7083
Cel. (567) 8782497
Las Condes, Santiago. Chile
URL: <
http://www.radiance-online.org/pipermail/radiance-general/attachments/20110410/c6c51caa/attachment-0001.html
End of Radiance-general Digest, Vol 86, Issue 5
