Radiance-general digest, Vol 1 #47 - 1 msg
Sorry, I didn't clarify very well the problem.
ximage doesn't start - strace ximage shows:
.... lots of stuff and then
open("/lib/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\300\330"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=1384040, ...}) = 0
old_mmap(NULL, 1201860, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40131000
mprotect(0x4024c000, 42692, PROT_NONE) = 0
old_mmap(0x4024c000, 28672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3,
0x11a000) = 0x4024c000
old_mmap(0x40253000, 14020, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40253000
close(3) = 0
munmap(0x40016000, 89170) = 0
fstat64(0, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 20), ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) =
0x40016000
read(0,
------------------------- Here is the xdpyinfo output:
name of display: :0.0
version number: 11.0
vendor string: The XFree86 Project, Inc
vendor release number: 40100000
XFree86 version: 4.1.0
maximum request size: 4194300 bytes
motion buffer size: 256
bitmap unit, bit order, padding: 32, LSBFirst, 32
image byte order: LSBFirst
number of supported pixmap formats: 7
     depth 1, bits_per_pixel 1, scanline_pad 32
     depth 4, bits_per_pixel 8, scanline_pad 32
     depth 8, bits_per_pixel 8, scanline_pad 32
     depth 15, bits_per_pixel 16, scanline_pad 32
     depth 16, bits_per_pixel 16, scanline_pad 32
     depth 24, bits_per_pixel 32, scanline_pad 32
     depth 32, bits_per_pixel 32, scanline_pad 32
keycode range: minimum 8, maximum 255
focus: window 0x2a00009, revert to PointerRoot
number of extensions: 22
     BIG-REQUESTS
     DPMS
     Extended-Visual-Information
     FontCache
     LBX
     MIT-SCREEN-SAVER
     MIT-SHM
     MIT-SUNDRY-NONSTANDARD
     RENDER
     SECURITY
     SHAPE
     SYNC
     TOG-CUP
     XC-APPGROUP
     XC-MISC
     XFree86-DGA
     XFree86-Misc
     XFree86-VidModeExtension
     XInputExtension
     XKEYBOARD
     XTEST
     XVideo
default screen number: 0
number of screens: 1
screen #0:
   dimensions: 1280x1024 pixels (433x347 millimeters)
   resolution: 75x75 dots per inch
   depths (7): 24, 1, 4, 8, 15, 16, 32
   root window id: 0x2d
   depth of root window: 24 planes
   number of colormaps: minimum 1, maximum 1
   default colormap: 0x20
   default number of colormap cells: 256
   preallocated pixels: black 0, white 16777215
   options: backing-store NO, save-unders NO
   largest cursor: 64x64
   current input event mask: 0xf84073
     KeyPressMask KeyReleaseMask EnterWindowMask
     LeaveWindowMask PointerMotionMask KeymapStateMask
     SubstructureNotifyMask SubstructureRedirectMask FocusChangeMask
     PropertyChangeMask ColormapChangeMask
   number of visuals: 2
   default visual id: 0x21
   visual:
     visual id: 0x21
     class: TrueColor
     depth: 24 planes
     available colormap entries: 256 per subfield
     red, green, blue masks: 0xff0000, 0xff00, 0xff
     significant bits in color specification: 8 bits
   visual:
     visual id: 0x22
     class: DirectColor
     depth: 24 planes
Hope this helps,
Ferdinand
[email protected] wrote:
Today's Topics:
   1. Re: Problems with Suse 7.3 (xfree86 4.1.0) and ximage (Peter Apian-Bennewitz)
--__--__--
Message: 1
Date: Sun, 06 Jan 2002 19:48:56 +0100
Subject: Re: [Radiance-general] Problems with Suse 7.3 (xfree86 4.1.0) and ximage
Reply-To: [email protected]
--------------927826C83C11FA1299376B3F
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Zack Rogers wrote:
> Hello,
> My office recently updated our linux systems from Suse 7.2 to Suse 7.3
> and now I cannot view any of Radiance .pic images. We believe it has to
> do with the newer X server xfree86 4.1.0. Has anyone else run into this
> problem or know how we can fix it? It is a real pain, I've been having
> to take my Linux Radiance images over to Windows NT to view them.
what happens when you run 'ximage' ? What's your 'xdpyinfo' output ?
The only problem I'm aware of is that ximage doesn't like some
bytes-per-pixel values, otherwise I hadn't heard of problems with Xfree 4.x
-Peter
> Thanks,
> Zack
> [email protected]
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Zack Rogers wrote:
<blockquote TYPE=CITE>Hello,
<p>My office recently updated our linux systems from Suse 7.2 to Suse 7.3
<br>and now I cannot view any of Radiance .pic images.&nbsp; We believe
it has to
<br>do with the newer X server xfree86 4.1.0.&nbsp; Has anyone else run
into this
<br>problem or know how we can fix it?&nbsp; It is a real pain, I've been
having
<br>to take my Linux Radiance images over to Windows NT to view them.</blockquote>
what happens when you run 'ximage' ?&nbsp; What's your 'xdpyinfo' output
<br>The only problem I'm aware of is that ximage doesn't like some bytes-per-pixel
values, otherwise I&nbsp;hadn't heard of problems with Xfree 4.x .
<br>-Peter
<blockquote TYPE=CITE>&nbsp;
<p>Thanks,
<br>Zack
<p>_______________________________________________
<br>Radiance-general mailing list
<br>[email protected]
<br><a href="http://www.radiance-online.org/mailman/listinfo/radiance-general">http://www.radiance-online.org/mailman/listinfo/radiance-general</a></blockquote>
<pre>--&nbsp;
&nbsp;pab-opto, Freiburg, Germany, www.pab-opto.de</pre>
&nbsp;</html>
--------------927826C83C11FA1299376B3F--
--__--__--
End of Radiance-general Digest
We have solved the problem. I feel a little foolish since it was a problem not really related to ximage, radiance or Suse7.3, still though, it's good to know for
anyone else who has the same setup. I access our linux machines through a VNC viewer, part of VMware Workstation. When we performed the upgrade from Suse 7.2 to
Suse 7.3 it overwrote my VNC settings, include the color/display settings. This changed the settings back to something like 8-bit which was not nearly enough to
view my Radiance pics. After changing this setting everything works fine. Thanks Peter for your help!
Zack Rogers
Today's Topics:
--__--__--
Message: 1
Zack Rogers wrote:
> Hello,
-Peter
> Thanks,
> Zack
> [email protected]
<html>
it has to
into this
having
<br>-Peter
<p>Thanks,
<br>Zack
<pre>--&nbsp;
&nbsp;</html>
--__--__--
