Radiance-dev Digest, Vol 16, Issue 4
Greg, Chas
Thanks for the help. I have moved this discussion to the general section as requested.
The white card method that Chas proposed was my "Plan B" if no white surfaces were available. I'll have to try the method that Greg suggested. The error message, "exposure out of range", that I receive is from pfilt.
Regarding the code modification, I am unsure if this method will work the way that I wish. If I am using a color, I could vary its hue with colorfunc but if I am using in image map with colorpict (wood floors are generally the most offending material with regard to color bleeding), I do not think that I can vary the color in accordance with a color bleeding parameter.
Thanks for all of everyone's help (including the email from cb)
Marcus
