Radiance compiled with mingw gcc (windows)
Hi all!
I've finally started looking at rtcontrib to replace my own scripts to
calculate daylight coefficients, and need to use it with windows
(unfortunately!) and without cygwin, so I've been "forced" to try the mingw
(http://www.mingw.org/) version of gcc to compile Radiance.
Scons has worked pretty well to compile most of the console programs.
I used these variables in platform\win32_custom.cfg:
[build]
CPPDEFINES: _WIN32 NDEBUG _CONSOLE _MBCS NON_POSIX
CCFLAGS: -O2 -DHDSUF=.exe
[code]
RAD_SPEED: -DSPEED=200 -DHDSUF=.exe
RAD_COMPAT: fixargv0.c
RAD_MATHCOMPAT: erf.c
RAD_MEMCOMPAT:
RAD_MLIB: m
RAD_PROCESS: win_process.c win_popen.c
and had to manually add some extra RAD_COMPAT inside a couple of SConstruct files
(maybe somebody can suggest a better CPPDEFINES line ...).
As for the source files:
1.
I had to redefine kill() inside rad.c and ranimate.c
using "RT_PID pid" instead of "int pid":
int
kill(RT_PID pid, int sig) /* win|unix_process.c should also wait and kill */
  return 0;
Also, inside win_process.c for the close_process() function:
was -----------------> int win_kill(pid, 0);
i've changed it to --> win_kill(pid, 0);
2.
The mingw version of signal.h doesn't have a definition for SIGALRM, so
killpersist() inside mkillum.c needs to be changed:
It is like this:
if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
but I've used SIGTERM instead of SIGALRM, don't know if this make much sense ...
3.
rtcontrib was calling rtrace with a wrong command line. It was something like
this:
c:\radiance\bin/rtrace.exe rtrace [args ...]
After some little searching I used this quick workaround inside win_process.c
          cmdpath = getpath(av[0], getenv("PATH"), X_OK);
added by me --> av[0] = "";
          cmdstr = quoted_cmdline(cmdpath, av);
that may have broken something somewhere else, so probably
a better solution would be to do some extra checks inside the _WIN32 section
of getpath.c.
I am interested only in rtcontrib right now, so I haven't checked
if other programs that call open_process() are still working or not.
4.
Mingw doesn't have fseeko(), and I replaced it with fseek() inside rtcontrib.c.
This seems to have broken the file output, that is working well with both
cygwin and linux. Is there an easy workaround for this? I don't have very
much experience to figure it out myself. Output to stdout now works fine ...
I hope not to have forgotten anything.
Sorry for the long email and thanks in advance,
Francesco
CC: gcc
Hi Francesco,
Thanks for giving this a try!
Date: September 11, 2005 6:09:37 AM PDT
Is this the target compiler we had in mind? I don't know anything about what's available under Windows, if schorsch (Georg Mischler) meant for people to use the more common (and nasty) Visual C standard. In other words, I'm not sure if by checking in these changes if I'd actually be making matters worse. For that reason, I'd prefer to leave Windows-related changes to schorsch, though I know he's been busy on other projects lately.
1.
int
    return 0;
This seems a safe enough change, though rtprocess.h, where RT_PID is defined, is not currently included in ranimate.c and will need to be added.
I don't know if this affects compatibility under other compilers, so I'll leave it to schorsch.
2.
It is like this:
The only difference this will make is that the waiting rtrace process will report an error instead of going quietly.
3.
this:
of getpath.c.
win_process.c is all schorsch's work, so he'll have to respond to this one as well.
4.
The original call:
     if (fseeko((FILE *)e->data, *(off_t *)p, SEEK_CUR) < 0) {
could be replaced by:
     if (fseek((FILE *)e->data, *(off_t *)p, SEEK_CUR) < 0) {
or even -Dfseeko=fseek on the compile line and it should work for files less than 2 GB in size. I assume that off_t is defined in your system, otherwise you would have had other errors. If it isn't defined as "long", then you might need another cast, like so:
     if (fseek((FILE *)e->data, (long)*(off_t *)p, SEEK_CUR) < 0) {
Once we find a working substitute, we can add the appropriate macro to platform.h.
Thanks for your help.
Well, Scons is "smart" enough to figure out what is available
in the system. Georg prepared a Visual C++ oriented platform
configuration for windows in the platform folder, so I guess
it is what he has used so far. Somebody else in this ml has used the
Borland compiler, if I remember well ...
Of course I can wait until Georg finds some time to reply.
I've just noticed I forgot to mention that I've also added
libws2_32 (-lws2_32) to the list of linked libraries to get
some programs compiled.
added.
Oh yes, I had to add it.
The original call:
to platform.h.
I've tried all of them, and they compile. What is strange is that
if I use both -f somefile.cal and -o somefile.dat, the program
exits nicely without writing the file, but if I remember well
only with windows, not with linux ... strange!
I don't think I'm doing anything wrong ...
I will check it twice, but anyway it is not a problem, since output
to stdout works perfectly to calculate daylight coefficients ...
BTW It looks like the mingw developer are going to add support for large
file system files at some point, probably later than sooner ...
Thanks again for your quick reply.
I think rtcontrib will definitely make my "Radiance life" simpler :wink:
It's oh so good to have all the contributions
from different light sources calculated separately at the same time !!!
Ciao ciao,
Francesco
the mingw
standard.
There's no target compiler per se. Compiler specific stuff is
defined in the platform/*.cfg files, and the SCons magic will
(hopefully) figure out which one to use.
The only difficulty here is that while we're compiling and
linking to the standard Windows libraries (apparently), the
gcc in mingw expects other command line arguments than the
VC compiler. We should create a seperate platform/mingw.cfg with
the parameters found. Francesco: Did you find any easy way to
tell the difference from within SCons/Python? We already have a
seperate *.cfg file for normal cygwin (using posix libraries),
but I don't remember how we figured out when to use that.
For the time being, you could try adding the following special
case to build_utils/load_plat.py (which should work, even if it's
not really pretty). I already checked in this change so it should
be in todays HEAD dump:
def load_plat(env, args, platform=None):
  for k,v in env.items(): print k,v
  if os.name == 'posix':
    POSIX_setup(env)
  if platform == None: # override
    p = sys.platform
  else: p = platform
  if p == 'win32' and 'gcc' in env['TOOLS']: # special case
    p = 'mingw'
  pl = []
  print 'Detected platform "%s" (%s).' % (sys.platform, os.name)
  [etc...]
Printing all items of env might produce better clues. Also, what
does mingw put in os.name and sys.platform?
of SConstruct files (maybe somebody can suggest a better
What were the RAD_COMPAT entries?
1.
int
and kill */
    return 0;
added.
Yes, the change as such is safe, although there were a few more
places where int needed to be replaced by RT_PID (and should have
been pid_t to start with). Of course, the real fix would be to
use our own process abstraction open_process() and friends
instead of fork() and exec(). In other words: both programs may
compile on Windows with those changes (now in CVS), but will not
necessarily work as expected yet.
win_kill() is a drop-in replacement for posix kill(), so it
must return an int for status information (even if it doesn't
actually do anything useful with it right now).
2.
SIGALRM, so
It is like this:
much sense ...
I'm not sure if I understand this right now (but then, I just
returned from Mongolia, so don't expect too much).
3.
something like
this:
win_process.c
_WIN32 section
of getpath.c.
this one as well.
I don't think your change breaks anything, but it's still not
the nice thing to do. Instead of feeding an empty string (which
results in a double width space in the command line) just pass
only the remainder of the argument list to quoted_cmdline():
  cmdstr = quoted_cmdline(cmdpath, av+1);
(Now in CVS)
I think this is save, because the first item will always be
the name of the command, and if there are no arguments, then
the second item will be NULL, which quoted_cmdline() should
handle correctly (I don't have a Windows system at hand right
now, though, so it's up to you to try...).
4.
rtcontrib.c.
with both
have very
fine ...
The original call:
to platform.h.
Microsoft only supports long files in the low level _lseeki64(), but
not in the stream routine(s). In the short term, -Dfseeko=fseek
looks like a reasonable workaround.
Actually, it seems that eg. recover_output() does both fseeko()
and lseek(fileno(fp)) on the same file (the latter through
myseeko()). Is this actually so? And if yes, what does it exactly
mean? Can we substitute _lseeki64(fileno(fp), offset, origin) for
fseeko(fd, offset, whence) when _FILE_OFFSET_BITS is set to 64 or
do the two calls have different semantics?
I also updated some of the SConscript files in CVS, most
prominently to work with the new tifflib, and a few other more
cosmetic changes.
-schorsch
What does this do? Is this a compatility layer added by mingw?
I just added a mingw specific config file to CVS:
ray/platform/mingw.cfg:
# platform specific settings for Windows (mingw)
# where you want everything
[install]
RAD_BASEDIR: c:\radiance3.6a
RAD_BINDIR: bin
RAD_RLIBDIR: share\lib
RAD_MANDIR: share\man
# shouldn't need any changes
[build]
CC: gcc
CPPDEFINES: _WIN32 NDEBUG _CONSOLE _MBCS HDSUF=.exe
CCFLAGS: -O2
LINKFLAGS: -lws2_32
[debug]
CC: gcc
CPPDEFINES: _WIN32 _DEBUG _CONSOLE _MBCS HDSUF=.exe
CCFLAGS: -g
LINKFLAGS: -lws2_32
# never touch below this
[code]
RAD_ARGSCOMPAT: fixargv0.c
RAD_MEMCOMPAT:
I moved some of your stuff to (hopefully) more appropriate lines,
and also corrected the other Windows config (VC6 and cygwin) in
the same way.
Nothing obvious that I can see here, but of course things could
go wrong in many different ways.
How are they planning to do this? They would have to extend the
system libraries, as far as I can tell.
-schorsch
Date: September 12, 2005 2:11:52 PM PDT
The -o option should work of course, and I would like it to work. It's needed for other things. If you change the line:
static void closefile(void *p) { fclose((FILE *)p); }
to:
static void closefile(void *p) { fputs("C",stderr); fclose((FILE *)p); }
You should get as many C's on your output as you have -o options. If that's not happening, it means this call is not being made as it should be. I'm trying it on my system now to make sure it's working here.
Date: September 13, 2005 2:32:14 AM PDT
The lseek() calls work underneath the stdio routines to get the file length, that's all. It puts the pointer back to the beginning when it's finished, and shouldn't interfere with stdio's notion of file position, which fseeko() is supposed to report. If this is broken in Windows, we'll have to dig out the other places I use this trick and find a substitute, but there's no indication it is broken as Francesco's problem case doesn't include the -r option, and otherwise recover_output() is never called.
Hi Greg + Georg, and thanks!
I'm answering to the questions of both of you within
this message ...
Since the platform is recognised as "win32"
I created my own platform\win32_custom.cfg
It puts "nt" and "win32". It is not like cygwin, that is a unix
system within windows. I compile from the standard windows C:\ prompt ...
I've added only "fixargv0.c", and copied the actual file inside
the utils and rt folders.
I had noticed the interesting Lighting Wiki sponsor before :wink:
(Now in CVS)
I was sure it was not an elegant solution. Tested and it works
and doesn't break anything. Thanks!
I haven't understood well it either. It is the winsock library,
so it may seem unrelated, but before adding it, the linker
was complaining about many linking errors, and adding it solved the
situation. I haven't investigated any further.
the same way.
The previous cygwin config file was working well, BTW ...
I don't know exactly the implementation details, but I guess so.
Cygwin already provides fseeko and ftello.
to:
here.
Unfortunately the call is not made when I use the -f switch.
It gets called only when I don't use the -f option.
One last thing, that should be unrelated with the other problems:
if run without any argument, rtcontrib segfaults.
Thank you,
Francesco
Hi Francesco,
Date: September 13, 2005 2:55:26 PM PDT
Then it's probable something is dying in the -f option processing that has nothing to do with fseeko(). I'm checking the library path with a call to getpath(), so if that was screwing up before, maybe it's screwing up during the -f processing as well.
Oops -- I added a check for no command-line arguments. Missed that one.
Creating an extra platform\mingw.cfg is the correct way to do it.
Those files are not just for each platform (despite the directory
name), they are for each compile environment.
This belongs to the RAD_ARGSCOMPAT config variable, which puts
the compiled objects into librtargs.a.
The generic RAD_COMPAT is actually obsolete.
Ah, that are the calls to gethostname().
VC uses a lot of magic to fund libraries when you include
certain headers, so very few explicit linker directives are
necessary. With gcc, we need to be more specific.
I added a new variable RAD_SOCKETLIB, the contents of which are
always linked to when -lrtnet is also present. This removes the
-lws2_32 from the generic LINKFLAGS.
Yes, but it's doing the same things in much cleaner ways now.
And here's the implementation:
  http://article.gmane.org/gmane.comp.gnu.mingw.user/11984
Unfortunately, fpos_t may be a struct on *some* Windows systems
(haven't found out which), and will then cause the build to fail.
But it seems reasonable to assume that this solution will work on
systems that support large files. It will probably end up in a
new file such as common/win_lfs.c.
Which means we need to check my Windows version of getpath().
Francesco, do you have a debugger available to trace through
this? Or does it get better if you specify fixargv0.c correctly
with the RAD_ARGSCOMPAT variable? Do you have the RAYPATH set
correctly? (for getrlibpath(), by default it uses ";c:\ray\lib")
-schorsch
Hi again,
I'm sorry for the late reply.
I wanted to send this message a couple of days
ago, but I didn't manage to find the time to write.
Georg, thanks for updating the Scons related files,
the compile process went better than before, only
a few things to change.
Two days ago I've downloaded the cvs snapshot
and here is the list of changes I did to get
Radiance compiled again with mingw (this time
I'm using diff, so I shouldn't miss anything ...):
diff -r ray/platform/mingw.cfg ray_dev/platform/mingw.cfg
13c13
< CPPDEFINES: _WIN32 NDEBUG _CONSOLE _MBCS HDSUF=.exe
CPPDEFINES: _WIN32 NDEBUG _CONSOLE _MBCS HDSUF=.exe NON_POSIX
18c18
< CPPDEFINES: _WIN32 _DEBUG _CONSOLE _MBCS HDSUF=.exe
CPPDEFINES: _WIN32 _DEBUG _CONSOLE _MBCS HDSUF=.exe NON_POSIX
25c25
< RAD_ARGSCOMPAT: fixargv0.c
RAD_ARGSCOMPAT: getpath.c fixargv0.c
28c28
< RAD_PROCESS: win_process.c win_popen.c
RAD_PROCESS: gethomedir.c eputs.c getpath.c win_process.c win_popen.c
29a30
RAD_MLIB: m
diff -r ray/src/common/rtprocess.h ray_dev/src/common/rtprocess.h
24c24
< int win_kill(RT_PID pid, int sig /* ignored */);
  int win_kill(RT_PID pid, RT_PID sig /* ignored */);
diff -r ray/src/common/SConscript ray_dev/src/common/SConscript
17c17
< font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c''')
    font.c mesh.c readmesh.c tmesh.c sceneio.c xf.c win_popen.c
win_process.c''')
diff -r ray/src/common/win_process.c ray_dev/src/common/win_process.c
284c284
< cmdstr = quoted_cmdline(cmdpath, av);
290c290
< int win_kill(RT_PID pid, int sig) /* we ignore sig... */
int win_kill(RT_PID pid, RT_PID sig) /* we ignore sig... */
328c328
< int win_kill(pid, 0);
      win_kill(pid, 0);
diff -r ray/src/gen/mkillum.c ray_dev/src/gen/mkillum.c
168c168
< if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGALRM) < 0)
  if (fscanf(fp, "%*s %d", &pid) != 1 || kill(pid, SIGTERM) < 0)
diff -r ray/src/gen/SConscript ray_dev/src/gen/SConscript
6a7
socketlib = env['RAD_SOCKETLIB']
35c36
< source=p[1], LIBS=p[2] + mlib)
            source=p[1], LIBS=p[2] + mlib + socketlib)
diff -r ray/src/rt/rtrace.c ray_dev/src/rt/rtrace.c
31a32
#include "random.h"
diff -r ray/src/util/ranimate.c ray_dev/src/util/ranimate.c
338c338,339
< if (errno == ENOENT && mkdir(vval(DIRECTORY), 0777) == 0)
/* if (errno == ENOENT && mkdir(vval(DIRECTORY), 0777) == 0)*/
    if (errno == ENOENT && mkdir(vval(DIRECTORY)) == 0)
diff -r ray/src/util/rtcontrib.c ray_dev/src/util/rtcontrib.c
342c342
979c979,980
< if (fseeko((FILE *)e->data, *(off_t *)p, SEEK_CUR) < 0) {
/* if (fseeko((FILE *)e->data, *(off_t *)p, SEEK_CUR) < 0) {*/
diff -r ray/src/util/SConscript ray_dev/src/util/SConscript
24a25,27
('rtcontrib', Split('rtcontrib.c') + [Version],
  ['rttrace', 'rtscene', 'rtpic', 'rtfunc', 'rtproc', 'rtio', 'rtmath',
  'rtargs', 'rtpath', 'rtcont', 'rtmem', 'rterror','ws2_32'])
34c37
< ['rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath',
  ['rtproc','rtpic','rtargs','rtio','rtcont','rtmem','rtpath','rtmath',
Unfortunately it is not working even with the latest changes.
Yep, the environment variables setup is fine.
Just to clarify, rtcontrib works well and writes the output file,
but only when I use the -f and -o options together, it doesn't write the
output file. If I use the -f option alone, it writes the results
to stdout, as required ...
I could use gdb, but probably will need some more days, I'm
pretty busy at work these days and the next week is going to
be busier than the previous one ...
Thanks again!
Francesco
13c13
NON_POSIX is set in common/platform.h based on _WIN32, so there
is no need to set it here. If you still get errors, then you
probably need to #include platform.h somewhere.
25c25
28c28
getpath.c is always included in librtargs.a. If a program needs it,
then you should link it to that library.
For gethomedir.c and getpath.c, link to librtpath.a.
For eputs.c, link to librterror.a.
For win_process.c and win_popen.c, link to librtproc.a.
With all those libraries, note that some linkers may require them
to be added in a certain order. So if a specific function isn't
found, it may be just necessary to reorder the list appropriately.
29a30
> RAD_MLIB: m
This was indeed an omission.
24c24
Ahem, no. The signal number doesn't have the same type as a PID.
It's rather the "pid" variable in rtcontrib.c:killpersist() that we
need to change.
What kind of problem were you trying to fix with this?
17c17
win_process.c''')
Never add platform specific files directly to the argument list.
That's what the compat variables are there for.
And those two files clearly have nothing at all to do with scene
file parsing, so it would be the wrong place to add them anyway.
Link to librtproc.a instead.
284c284
Correct as discussed.
290c290
Again: A signal number doesn't have the same type as a PID.
328c328
> win_kill(pid, 0);
Yeah, that did indeed look strange...
6a7
35c36
Which programs asked for this?
You can instead add '$RAD_SOCKETLIB' to those that really need it
(and tell me which ones those are, so I can put it into CVS).
31a32
> #include "random.h"
Looks like Windows does indeed need this.
338c338,339
I added a macro to common/paths.h which should take care of this.
168c168
342c342
For the moment, I added macros that redefines SIGALRM as SIGTERM
if the former is not known, which is a portable workaround.
There are two things to consider here (for Greg, primarily):
First, both mkillum and rtcontrib define an identical(!) function
named killpersist(). This is bad design, because redundant code
multiplies potential errors.
Second: kill() on Windows is currently equivalent to the brute
force kill(pid, SIGKILL) on unix, where the actual signal number
is completely ignored. This means that rtrace can't do the
cleanup that it otherwise would do.
I think that all this persistence magic should be moved to our
process management library, so that it can be handled in a
platform independent manner with all functionality preserved.
979c979,980
We better solve this temporarily via -Dfseeko=fseek in mingw.cfg,
until the actual replacement for fseeko() is ready.
24a25,27
34c37
I changed the sequence here a little, which may or may not matter.
More importantly, I changed 'ws2_32' to '$RAD_SOCKETLIB'.
I also modified the build procedure for ranimate, so that the
decision between util/netproc.c and util/win_netproc.c is made
in the *.cfg file through the RAD_NETCOMPAT variable. This has
moved one more platform specific detail away from the local
SConscript files.
I commited all the changes to CVS and checked that it still
compiles on Linux. There may be two or three small things that
you still need to look at more closely for mingw. I assume that
all of those changes are also beneficial for compiling with VC,
so this is a very valueble contribution!
-schorsch
Hi Greg and Georg,
I've just re-compiled Radiance with mingw, and it has been easier.
Also, the rtcontrib file output problem has disappeared, and I think
it has been fixed at revision 1.27
Here is the list of changes I've done to the Scons scripts,
I hope this time they make more sense:
diff -r ray/platform/mingw.cfg ray_ok/platform/mingw.cfg
13c13
< CPPDEFINES: _WIN32 NDEBUG _CONSOLE _MBCS HDSUF=.exe fseeko=fseek
CPPDEFINES: _WIN32 MINGW NDEBUG _CONSOLE _MBCS HDSUF=.exe fseeko=fseek
18c18
< CPPDEFINES: _WIN32 _DEBUG _CONSOLE _MBCS HDSUF=.exe fseeko=fseek
CPPDEFINES: _WIN32 MINGW _DEBUG _CONSOLE _MBCS HDSUF=.exe fseeko=fseek
(I've added the MINGW macro to fix the following problem in rpict)
diff -r ray/src/rt/rpict.c ray_ok/src/rt/rpict.c
16a17
#ifndef MINGW
17a19,21
#else
#include <sys/time.h>
#endif /* MINGW */
(this is because <sys/times.h> is not available with mingw,
while <sys/time.h> is)
diff -r ray/src/gen/SConscript ray_ok/src/gen/SConscript
6a7
27,28c28,29
< ('mkillum', Split('mkillum.c mkillum2.c mkillum3.c'),
< ['rtproc','rtscene','rtpath','rtmath','rtio','rtcont','rterror']),
#('mkillum', Split('mkillum.c mkillum2.c mkillum3.c'),
# ['rtproc','rtscene','rtpath','rtmath','rtio','rtcont','rterror']),
33a35
44c46,53
< 'rtmath','rtcont','rtmem','rtargs','rtpath','rterror'] + mlib)
    'rtmath','rtcont','rtmem','rtargs','rtpath','rterror','rtproc'] + mlib)
progs.append(prog)
prog = env.Program(target=os.path.join('$RAD_BUILDBIN', 'mkillum'),
    source=Split('mkillum.c mkillum2.c mkillum3.c'),
    CPPPATH=env.get('CPPPATH', []) + ['#src/rt'],
    LIBS=['raycalls','rttrace','rtscene','rtpic','rtfunc','rtio',
+ socketlib)
(I've taken mkillum out of the prog targets, because it needs "socketlib",
and slightly changed the mksource library list)
diff -r ray/src/ot/SConscript ray_ok/src/ot/SConscript
17,18c17,18
< source=p[1], LIBS=['rtproc','rtscene','rtio','rtpath','rtmath',
< 'rtargs','rtcont','rtmem','rterror']+mlib)
      source=p[1], LIBS=['rtscene','rtio','rtpath','rtmath',
      'rtargs','rtcont','rtmem','rterror','rtproc']+mlib)
(worked only when I moved rtproc to the end of the list)
diff -r ray/src/px/SConscript ray_ok/src/px/SConscript
43c43
< ('ra_bmp', ['ra_bmp.c'], ['rtpic','rtproc','rtio','rtmem']),
['rtpic','rtmem','rtproc','rtio','rtargs','rterror','rtpath']),
(additional libraries required to compile ra_bmp)
diff -r ray/src/util/rad.c ray_ok/src/util/rad.c
1515c1515,1516
< RT_PID pid, sig;
RT_PID pid;
int sig;
(sig needs to be declared as int)
diff -r ray/src/util/rpiece.c ray_ok/src/util/rpiece.c
11a12,13
#include "platform.h"
16d17
< #include "platform.h"
(platform.h needs to be included before #ifndef NON_POSIX)
The binaries are available here:
http://www.bozzograo.net/radiance/modules.php?op=modload&name=Downloads&file=index&req=getit&lid=12
Francesco
