[Radiance and Brad] MacosX and X11 and bra d anblender
just have a morning chat with the main brad guru:
Francesco itself ;-)))
we tried different things and we think to have identified the problem:
-1- make sure that ximage works at all on your system (just a silly check,
but you never know)
-2- if ximage works, the solution is then to start blender from the
terminal.
to do that you need to go into:
blender.app/contents/macos
in fact blender.app is a folder folder as all macosx applications
(to browse it you need to ctlr+click on it and ask for 'show contents' in
the contextual menu)
when you are into
just type:
./blender
the GUI starts and everything works.
plus you are able to see error messages in the terminal window (good if you
need to fix a problem)
only small problem is that the window is larger than the screen, but you can
adjust the menu position by dragging them.
hope it works now
cheers
giulio
francesco
[mailto:[email protected]]On Behalf Of J.
Sienknecht
Sent: 13 January 2005 21:51
To: radiance
Subject: [Radiance-general] [Radiance and Brad] MacosX and X11 and brad
anblender
Hello everyone! I'm really new to radiance and first I have to say:
Thank You Very Much For Developing And Supporting This Free Software!!
Radiance is running fine on my system (far as i can see) with macos 10.3.7,
blender 2.3.6, python 2.3.
My question is more about blender and brad because
everything seems to work in general, but if i try the sky preview
i get the following in the console window:
" ximage
/Applications/Blender/blender.app/Contents/MacOS/.blender/scripts/brad/tmp/
mph.pic: cannot open display"
I've edited my bash_profile like it was explained from pillo:
if someone is interested in using x11 as graphical output for the built
in panther terminal this is what is required:
1) launch x11, launch terminal (keep X11 always open when the terminal
is open, otherwise it doesn't work!)
2) edit your .bash_profile as follows, just add these lines:
if [ -z "${DISPLAY}" ];then echo -n
export DISPLAY=':0'
fi
but sadley it has not the desired (display-) effect to applications
controlled via brad/blender, too.
would it be possible to open x-window-radiance-applications like ximage out
of blender/python in a way that they use x-darwin and its display?
thank you very much and all the best
johannes
