rad program
I checked the rad. It has a good feature. But I am a little confused with
several variable settings
*rad* [ *-s* ][ *-n|-N* *npr* ][ *-t* ][ *-e* ][ *-V* ][ *-w* ][ *-v* *view*][
*-o* *device* ] *rfile* [ *VAR=value* *..* ]
(1) is that right the option [-v view] and "view" variable in .rif have the
same function?
(2) For three sets (1) "OCTREE", (2)"scene" (3) "object" and "materials" ,
if I change files in "object" and "material", will .oct be updated when I
run "rad -t sample.rif" ? Similarly, if I change files indicated in
"scene", the oct. will be updated even if "OCTREE" is not changed?
Jia
On Thu, Jul 8, 2010 at 3:18 PM, Christopher Rush <[email protected]>wrote:
You can even call rad from within a script.
Define only the common settings for rad within the rif file, and those that
change after each rad command within the script (scene=___ PICTURE=___ ).
Check the rad manual page for usage syntax.
A few of rad’s variables assign naming of output files, including PICTURE,
OCTREE, RAWFILE, and AMBFILE (others?). Be sure to assign these names
differently for each option in the script, otherwise your output images will
default to common rif file name, or you could accidentally share an ambient
file between options.
rad [ -s ][ -n|-N npr ][ -t ][ -e ][ -V ][ -w ][ -v view ][ -o device ] rfile [ VAR=value .. ]
(1) is that right the option [-v view] and "view" variable in .rif have the same function?
If your rif file has a line that looks like "view= viewname [parameters]" then your -v command line option to rad would look like "-v viewname." Otherwise it will run all views listed in the rif file.
(2) For three sets (1) "OCTREE", (2)"scene" (3) "object" and "materials" , if I change files in "object" and "material", will .oct be updated when I run "rad -t sample.rif" ? Similarly, if I change files indicated in "scene", the oct. will be updated even if "OCTREE" is not changed?
Correct. It should automatically check the input files every call of the rad command and update the .oct file if required, even without the -t option. The -t option is meant specially for a case that you want to update the .oct file, but not create any renderings from it.
