rad -n and -N parameters / switches (was: how to use pfilt to perform anti-aliasing)
Hi!
[ *-n|-N* *npr* ]
1. Does this mean the"-n" and"-N npr" options are mutually exclusive?
Somehow - if you do not do any processing (-n), no processes can be started (-N npr)... somehow it is confusing, maybe separating the two in the manpage would be clearer. -n also affects all other options in the same way :wink:
2. Does"-N 3" mean the task to generate an .hdr image will be split into 3 parallel rendering processes by Radiance behind the scene regardless of the number of CPUs and number of"cores" within each CPU of the computer?
Radiance does not take your decisions. People on 4core-machines may have good reasons to render on two (and keep the remaining two cores busy with other tasks). So Radiance listens to you and will start as many render processes as you specify by -N 3.
Note: I changed the subject line to match the topic.
Dear Lars,
Thanks for your prompt reply!
I've tried the "-N npr" option, and here's the error message i got when i
run "rad -N 6 ./test.rif" or "rad -N 4 ./test.rif" or "rad -N 2 ./test.rif":
rpiece: no NFS lock manager on this machine
rad: error rendering view 1
I don't know the meaning of the error message, and I found no information by
searching the email list.
However, It seems I can get rad up and running by using "rad -N 1
./test.rif" or just "rad ./test.rif".
I'm using a PC with Inter Core i7 CPU (8 cores, I guess based on what I see
on the task manager... )
So, can you kindly advice me on:
1. why the "-N 6" cann't be accepted when I want to utilize 6 of the 8 cores
of my CPU to speed up the rendering?
2. dose the npr means "number of processors/CPU" rather than "number of
cores within each CPU"?
3. how to specify rad options to harness multi-core CPU's capability?
Thanks!
Ji
On Thu, Jun 16, 2011 at 5:18 PM, Lars O. Grobe <[email protected]> wrote:
Hi!
[ *-n|-N* *npr* ]
Radiance-general@radiance-**online.org<[email protected]>
http://www.radiance-online.**org/mailman/listinfo/radiance-**general<http://www.radiance-online.org/mailman/listinfo/radiance-general>
