Question concerning genprism
Hi all:
I’m learning Radiance and ran into an issue concerning genprism. According
to the book, I typed down the command below. Whenever I tried to oconv the
material1.rad & stool_1.rad, it gives me errors below. Someone using Linux
system can fix the issue by setting the PATH environment. I already set the
PATH, RAYPATH, and MANPATH in both .profile and .bashrc. I’m wondering if
there’s any other way of solving the problem.
Thank you in advance.
Zhe
    Error below:
    T1 > more ./lib/stool_1.rad
    # stool_1.rad
    brown_satin_paint polygon stool_top
    12 -0.75 -0.75 2.6
           0.75 -0.75 2.6
           0.75 0.75 2.6
           -0.75 0.75 2.6
    # using the modifier brown_satin_paint. create a polygon. named
stool_top
    !genprism brown_satin_paint stool_leg_se \
             4 0.7 -0.7 0.7 -0.6 0.6 -0.6 0.6 -0.7 -l 0 0 2.5
    !genprism brown_satin_paint stool_leg_ne \
- Ignored:
             4 0.7 0.7 0.6 0.7 0.6 0.6 0.7 0.6 -l 0 0 2.5
    !genprism brown_satin_paint stool_leg_nw \
             4 -0.7 0.7 -0.7 -0.6 -0.6 0.6 -0.6 0.7 -l 0 0 2.5
    !genprism brown_satin_paint stool_leg_sw \
             4 -0.7 -0.7 -0.6 -0.7 -0.6 -0.6 -0.7 -0.6 -l 0 0 2.5
    T1 > oconv material1.rad ./lib/stool_1.rad > stool_1.oct
     : cannot open
    oconv: warning - (!genprism brown_satin_paint stool_leg_se \ ): empty
file
    oconv: fatal - (./lib/stool_1.rad): undefined modifier "4"
    Usage: genprism material name { - | vfile | N v1 v2 .. vN } [-l
lvect][-r radius][-c][-e]
    oconv: warning - (!genprism brown_satin_paint stool_leg_se\ ): empty
file
*Zhe Kong*
*PhD Student*
*University of Wisconsin - Milwaukee *
*School of Architecture and Urban Planning *
*2131 E. Hartford Ave, Milwaukee, WI 53211 *
*Office 327*
Try removing the "\" and just joining the lines in your file, like so:
# using the modifier brown_satin_paint. create a polygon. named stool_top
!genprism brown_satin_paint stool_leg_se 4 0.7 -0.7 0.7 -0.6 0.6 -0.6 0.6 -0.7 -l 0 0 2.5
I'm guessing that the Windows command line doesn't like the escaped newlines.
Subject: [Radiance-general] Question concerning genprism
Date: June 13, 2015 5:28:56 PM PDT
Hi all:
I’m learning Radiance and ran into an issue concerning genprism. According to the book, I typed down the command below. Whenever I tried to oconv the material1.rad & stool_1.rad, it gives me errors below. Someone using Linux system can fix the issue by setting the PATH environment. I already set the PATH, RAYPATH, and MANPATH in both .profile and .bashrc. I’m wondering if there’s any other way of solving the problem.
Zhe
    Error below:
    # stool_1.rad
    12 -0.75 -0.75 2.6
           0.75 -0.75 2.6
           0.75 0.75 2.6
           -0.75 0.75 2.6
- Ignored:
     : cannot open
    oconv: warning - (!genprism brown_satin_paint stool_leg_se \ ): empty file
    Usage: genprism material name { - | vfile | N v1 v2 .. vN } [-l lvect][-r radius][-c][-e]
    oconv: warning - (!genprism brown_satin_paint stool_leg_se\ ): empty file
Zhe Kong
PhD Student
Office 327
