Question about Segmentation fault: 11
Hello everyone:
I have a question concerning Radiance in Mac. I export the model from Rhino, and the rendering works well in Window system. Then I copy all the text files in Mac, the terminal gives me “Segmentation fault: 11”. I saw others ran into the same error with gendaylit. But no matter with or without a sky file (I have artificial lights for night occasion), the file gives the same error. Does anyone else have the same experience?
Please feel free to ask for my file it you’d like to help me figure out. It is too large to share them.
Thank you in advance.
Zhe
More information is needed. Which program where you running when you got the error, and on which file(s)?
Subject: [Radiance-general] Question about Segmentation fault: 11
Date: September 23, 2015 3:08:25 PM PDT
Hello everyone:
Zhe
Zhe,
I suspect line endings are causing your problem. Windows uses CR/LF as a
line ending. Unix uses LF. Often when a text file is created on Windows you
need to convert the line endings when those files are brought to Mac. Text
editors are usually fine with either, so it may not be noticeable when you
open the file in a text editor.
Here are some ways to do the conversion
Also, some text editors (such as Text Wrangler) allow you to set the line
endings when you do a save-as.
Andy
On Wed, Sep 23, 2015 at 3:08 PM, zhekong <[email protected]> wrote:
Hello everyone:
Zhe
