Question About RAY type member
Dear Group
I am wondering if anyone could shed some light on the RAY type member 'rod'. I am curious as to how and why this is used. I am assuming that it has something to do with the fact that all object in Radiance are two sided and this relates the surface normal orientation wrt the ray being traced. Then again, I am probably wrong. Out of curiosity, if it is already known that all surface normal for faces are properly oriented (i.e. facing the viewer), is it necessary to calculate this value?
Thanks
Marcus
Watch LIVE baseball games on your computer with MLB.TV, included with MSN Premium! http://join.msn.com/?page=features/mlb&pgmarket=en-us/go/onm00200439ave/direct/01/
Hi Marcus,
The rod member is a minor optimization to avoid the need to repeatedly compute -DOT(rdir,ron). It does not flip the surface the right way around -- some material routines do this by calling the flipsurface() function. Why do you want to know?
Date: April 13, 2004 12:24:26 PM PDT
Dear Group
Thanks
Marcus
Thanks Greg for the info.
I did take a look through the source code. When I first looked, this value appeared to only be used in logical statements. After looking further, I can see that this value is used to calculate other values.
The reason I have interest in this is because I am looking to implement an optimization to Radiance for ray-triangle intersection. From what I can tell, Radiance uses generic routines for calculating ray/n-sided polygon intersection and nothing specific for triangles. Since the geometry for my scenes, with the exception of light sources, consist entirely of triangles, I want to optimize the code a bit. The ray-triangle intersection algorithm that I am going to use is the M�ller-Trumbore method listed here:
http://www.acm.org/jgt/papers/MollerTrumbore97/
It seems pretty straight forward to implement. There are two branches to the code, culling and non-culling. I am going to implement both and do a performance comparision. The reason I asked whether about the member 'rod' is because I only want to calculate only what is necessary. Since I am implementing the culling branch of the M�ller-Trumbore algorithm first, I was curious as to whether or not the value would be needed if I am doing backface culling. I see now that I will need it. If this is sucessful and I can achieve a modest performance increase, I may look to implement the algorithm into o_mesh.c
BTW, the dicussion that we had last month about tmesh.cal worked great for me. With the revision to the source code to my conversion program, I achieved a 10.5% - 12.5% gain in performance.
Thanks
Marcus
Date: Tue, 13 Apr 2004 12:51:50 -0700
Subject: Re: [Radiance-dev] Question About RAY type member
To: code development <radiance-dev@radiance-online.org>
Message-ID: <014886D8-8D84-11D8-B1AE-000A95BB392A@lmi.net>
Content-Type: text/plain; charset=US-ASCII; format=flowed
Hi Marcus,
> From: "Marcus Jacobs" <marcdevon@hotmail.com>
> Dear Group
> value?
> Thanks
> Marcus
Persistent heartburn? Check out Digestive Health & Wellness for information and advice. http://gerd.msn.com/default.asp
Hi Marcus,
I'm already using a supposedly fast triangle intersection test in rt/o_mesh.c -- didn't you look? It uses the following algorithm by Segura & Feito, which the they compare favorably to Moller's technique:
  http://wscg.zcu.cz/wscg2001/Papers_2001/R75.pdf
If you feel like implementing Moller's method and comparing it to Segura & Feito, be my guest, but I bet they're pretty similar. The legacy Radiance code for general polys is probably faster in fact, since it stores and reuses surface normal information. I don't do this in meshes due to the storage overhead.
I also implemented my own optimization in o_mesh.c that cuts the number of cross products approximately in half, since neighboring faces are usually tested together.
Date: April 14, 2004 8:19:27 AM PDT
The reason I have interest in this is because I am looking to implement an optimization to Radiance for ray-triangle intersection. From what I can tell, Radiance uses generic routines for calculating ray/n-sided polygon intersection and nothing specific for triangles. Since the geometry for my scenes, with the exception of light sources, consist entirely of triangles, I want to optimize the code a bit. The ray-triangle intersection algorithm that I am going to use is the Möller-Trumbore method listed here:
It seems pretty straight forward to implement. There are two branches to the code, culling and non-culling. I am going to implement both and do a performance comparision. The reason I asked whether about the member 'rod' is because I only want to calculate only what is necessary. Since I am implementing the culling branch of the Möller-Trumbore algorithm first, I was curious as to whether or not the value would be needed if I am doing backface culling. I see now that I will need it. If this is sucessful and I can achieve a modest performance increase, I may look to implement the algorithm into o_mesh.c
Hi Greg
To be honest with you, I have only glanced through o_mesh.c. I thought I would mention that I would use M�ller-Trumbore for optimization just as an off hand thought as I was sending a reply and to get your comments on it. Since o_mesh uses the Segura & Feito method, I see no reason to try to implement M�ller-Trumbore. Though, I may look to store and reuse the surface normal values since I have a couple of gigs of memory to play with on my machine. I'll have to evaluate it later. If I am correct though, M�ller-Trumbore doesn't use the surface normal values in order to test for intersection (though the values will be stored). Thank you for all of your insight.
Marcus
To: "Marcus Jacobs" <marcdevon@hotmail.com>
CC: code development <radiance-dev@radiance-online.org>
Subject: Re: Question About RAY type member Date: Wed, 14 Apr 2004 08:54:20 -0700
Hi Marcus,
Free up your inbox with MSN Hotmail Extra Storage! Multiple plans available. http://join.msn.com/?pgmarket=en-us&page=hotmail/es2&ST=1/go/onm00200362ave/direct/01/
