Python script
Hi all.
I am about to release version 0.2 of a set of python scripts that pre/post-process Radiance scenes from a 3D modelling package called Blender. I have implemented Dynamic Daylight Simulations in version 0.2, which is fine on Linux/Mac but it's causing me a problem on windows machines. When python, using Popen, sends out the command piping gendaylit to genskyvec.pl I get a bad sky description error, although if I type the same command into the Windows command prompt it works as expected. Has anyone here got any experience of running this combination on windows with Python. I'm using strawberry Perl to run the genskyvec.pl file, which was part of NREL's latest binary release.
Thanks in advance
Ryan
Dr Ryan Southall
Senior Research Fellow
School of Architecture & Design
University of Brighton
___________________________________________________________
This email has been scanned by MessageLabs' Email Security
System on behalf of the University of Brighton.
For more information see http://www.brighton.ac.uk/is/spam/
Hi Ryan.
Interesting that Blender is coming back to Radiance. I am following the
Python API development but I'm still not sure it has all the bells and
whistles to make it worth the effort.
Regarding your Popen problem: Do you have problems with other Perl scripts
as well or is it only genskyvec.pl?
I do remember that I had some issues with command lines and Popen on
Windows when I was writing falsecolor2. It's mostly the correct quoting of
the arguments. I don't recall doing anything specific that solved my
problem, though.
Can you test your code outside of Blender in plain Python or do you have
too many dependencies on the Blender modules?
On Mon, Jul 16, 2012 at 12:14 PM, Ryan Southall <R.Southall@brighton.ac.uk>wrote:
Hi all.
Thanks in advance
Ryan
Dr Ryan Southall
______________________________**_____________________________
For more information see http://www.brighton.ac.uk/is/**spam/<http://www.brighton.ac.uk/is/spam/>
Radiance-general@radiance-**online.org<Radiance-general@radiance-online.org>
http://www.radiance-online.**org/mailman/listinfo/radiance-**general<http://www.radiance-online.org/mailman/listinfo/radiance-general>
Thanks Thomas.
The API is pretty complete now but still changes due to evolving Blender functionality. I have to do quite a bit to port my scripts to the 2.63 BMesh version for example. genskyvec.pl works when I simply type the command sequence into the windows terminal, it just seems that when executing the command sequence with Popen the data from gendaylit is not correctly understood by genskyvec.pl. Running simply within Python is a good idea, I'll try that.
Ryan
Dr Ryan Southall
That's what I thought. I think I can wait a bit longer for it to stabilise.
genskyvec.pl.
You can also hack the genskyvec.pl script and add a line to print out the
input that the script actually gets. If this is not what you expect it to
be then you have to look at your use of Popen again.
On Mon, Jul 16, 2012 at 6:14 PM, Ryan Southall <R.Southall@brighton.ac.uk>wrote:
Hi Folks…
On 7/16/12 5:01 AM, "Thomas Bleicher" <tbleicher@googlemail.com<mailto:tbleicher@googlemail.com>> wrote:
Hi Ryan.
Interesting that Blender is coming back to Radiance. I am following the Python API development but I'm still not sure it has all the bells and whistles to make it worth the effort.
Regarding your Popen problem: Do you have problems with other Perl scripts as well or is it only genskyvec.pl<http://genskyvec.pl>?
This is happening with our Ruby scripts as well…
I do remember that I had some issues with command lines and Popen on Windows when I was writing falsecolor2. It's mostly the correct quoting of the arguments. I don't recall doing anything specific that solved my problem, though.
…I will look at the quotes.
On Mon, Jul 16, 2012 at 12:14 PM, Ryan Southall <R.Southall@brighton.ac.uk<mailto:R.Southall@brighton.ac.uk>> wrote:
Hi all.
I am about to release version 0.2 of a set of python scripts that pre/post-process Radiance scenes from a 3D modelling package called Blender. I have implemented Dynamic Daylight Simulations in version 0.2, which is fine on Linux/Mac but it's causing me a problem on windows machines. When python, using Popen, sends out the command piping gendaylit to genskyvec.pl<http://genskyvec.pl> I get a bad sky description error, although if I type the same command into the Windows command prompt it works as expected. Has anyone here got any experience of running this combination on windows with Python. I'm using strawberry Perl to run the genskyvec.pl<http://genskyvec.pl> file, which was part of NREL's latest binary release.
Thanks in advance
Ryan, thanks for reporting this. I think we are probably both in the same boat, and it's preventing Windows OpenStudio users to do a full annual simulation with our Radiance implementation scripts too. We are looking into a fix right now.
Hi Ryan, do you use wait() after Popen()?
Jia
On Wed, Jul 18, 2012 at 1:20 PM, Guglielmetti, Robert < Robert.Guglielmetti@nrel.gov> wrote:
Hi Folks…
On 7/16/12 5:01 AM, "Thomas Bleicher" <tbleicher@googlemail.com<mailto: > tbleicher@googlemail.com>> wrote:
Hi Ryan.
problem, though.
On Mon, Jul 16, 2012 at 12:14 PM, Ryan Southall <R.Southall@brighton.ac.uk > <mailto:R.Southall@brighton.ac.uk>> wrote:
Hi all.
binary release.
Thanks in advance
Jia
I haven't been Jia. I can give it a go if you think it will help, but it is not required on OSX/linux.
As running a perl script from a python script smacks of a certain inefficiency I might try and recode genskyvec into python. If anyone has a link to info about what genskyvec is doing, or an idiot's guide to perl for that matter, I'd love to hear from you.
Ryan
Dr Ryan Southall
Ryan,
I'm not sure how inefficient that is, the overhead of an additional
interpreter is trivial these days. For info about what genskyvec is doing,
you should start with the man page, and then simply read the Perl code.
But I'd advise against a full rewrite; I think we just need to figure out
what the problem is with the Perl script. We have found that Genskyvec
fails on multiple XP machines, all running ActiveState Perl. I will try
Strawberry Perl next, but I know I'm grasping at straws here.
Golden, CO 80401
303.275.4319
robert.guglielmetti@nrel.gov
Jia
a
Ryan
Dr Ryan Southall
Hi all.
I played around with the script this morning and found that genskyvec
doesn't receive any input via the pipe on Windows XP. I googled around a
bit and it seems that this is a limitation of cmd.exe on Windows XP. Vista
and newer seem to work (just relying on Google here, did not test it
myself.) Some information can be found here:
http://www.perlmonks.org/?node_id=859261
As a work around you can specify the command as
gensky 3 21 12 | perl -S genskyvec.pl
This at least solves the problem of the empty pipe. It should work in a
Python Popen command, too.
On Thu, Jul 19, 2012 at 6:26 PM, Guglielmetti, Robert < Robert.Guglielmetti@nrel.gov> wrote:
Hi Thomas,
Thanks for the research! Unfortunately, this workaround resulted in this mess:
Hmmm…
C:\>gensky 6 21 12 | perl -S genskyvec.pl -m 1
Access is denied.
rtrace: system - cannot open octree file "gtv3136.oct": No such file or director
y
Use of uninitialized value in split at C:\Program Files\radiance\bin/genskyvec.p
l line 142, <> line 19.
Use of uninitialized value in print at C:\Program Files\radiance\bin/genskyvec.p
l line 148, <> line 19.
2192.70042363985 2192.70042363985 2192.70042363985
1857.68156664449 1857.68156664449 1857.68156664449
5432.42679727898 5432.42679727898 5432.42679727898
C:\>
I think I had the same error during testing. After I set RAYPATH to the lib
folder in the new installation it worked fine. Is your RAYPATH set
correctly at the cmd prompt? I also did not use any arguments like "-m 1"
for testing.
On Fri, Jul 20, 2012 at 5:54 PM, Guglielmetti, Robert < Robert.Guglielmetti@nrel.gov> wrote:
Hi Thomas,
mess:
Hmmm…
Access is denied.
director
y
C:\>
I can't remember if I replied to this or not. I am old.
Anyway, Thomas, RAYPATH is indeed set correctly. We are considering dropping support for WindowsXP at this point, seeing as how it's almost as old as I am, and these scripts work fine on Windows7 (soon to be supplanted by Windows8). The reason I replied to the list is because I'm curious:
Is anyone running Radiance on WindowsXP anymore? Email me offlist (robert.guglielmetti@nrel.gov) if you have a sec, listers. Just trying to get a sense of how many XP/Radiance users are out there.
Golden, CO 80401
303.275.4319
On 7/20/12 11:31 AM, "Thomas Bleicher" <tbleicher@googlemail.com<mailto:tbleicher@googlemail.com>> wrote:
I think I had the same error during testing. After I set RAYPATH to the lib folder in the new installation it worked fine. Is your RAYPATH set correctly at the cmd prompt? I also did not use any arguments like "-m 1" for testing.
On Fri, Jul 20, 2012 at 5:54 PM, Guglielmetti, Robert <Robert.Guglielmetti@nrel.gov<mailto:Robert.Guglielmetti@nrel.gov>> wrote:
Hi Thomas,
Hmmm…
C:\>gensky 6 21 12 | perl -S genskyvec.pl<http://genskyvec.pl> -m 1
Access is denied.
y
C:\>
Radiance-general@radiance-online.org<mailto:Radiance-general@radiance-online.org>
