Python script (perl -S 'works')
Hi.
I can confirm that Thomas' suggestion to use prepend genskyvec.pl with 'perl -S' appears to work on a windows 7 machine when run from a Python script. I have not tested numerical correspondence with OSX/linux yet as I am still going through the remainder of my code to get it to work with the windows command line (a process which is very much like extracting one's own teeth).
Ryan
On Wed, 25 Jul 2012 20:00:00 +0100, <[email protected]> wrote:
Today's Topics:
   1. Re: partly covered source (Thomas Bleicher)
   2. Re: BSDF xml into Radiance (Greg Ward)
   3. Genskyvec error revisited (Guglielmetti, Robert)
Message: 1
Date: Wed, 25 Jul 2012 15:01:11 +0200
Subject: Re: [Radiance-general] partly covered source
Message-ID:
  <CAKGV-k3sBnDu3WCYOx9L723x1n-28HP80MvxNmyOQ8izTmbehA@mail.gmail.com>
Jan
You could get the direction of the sun from your sky description and point
rtrace in that direction and only get the material (-om). You can add your
own variations to sample the whole disc to calculate the visible part of
the sun if that's what you need.
On Tue, Jul 24, 2012 at 9:50 PM, Jan Wienold > <[email protected]>wrote:
Hi Giulio, hi all,
unfortunately it doesn't work out safely. In total I have many, many cases
to look at (in total 40000 timesteps x 33 points x 2geometries) and there
are still many cases, when rtrace doesn't catch the sun.
Since these are calculations for an expertise, which is used for a trial,
I have to be absolutely sure not to miss any case...
Is there any idea except calculating images ? Source subdivisions are
unfortunately not possible when "source" is used...
Thanks!
Jan
On 07/24/2012 02:13 AM, Jan Wienold wrote:
hi giulio,
Yes!
The use of -dj helped, but only if I use also the -u option. Otherwise I
still get randomized zero values, also if I change -ds.
thanks!
jan
On 07/24/2012 01:35 AM, giulio antonutto wrote:
Jan,
maybe you can fix it with -dj and oversampling?
G
On 24 Jul 2012, at 00:03, Jan Wienold wrote:
I just encountered a strange different behavior between rtrace and
rpict:
If the sun ( using "source") is covered in large parts (in that case
more than half) I can still "see" the uncovered parts in the image (=>this
is what I expect). In case I calculate at the same point and in the same
direction the illuminance with rtrace -I, I get zero contribution. Is just
the center of the source description tested in that case? Any solution for
this for rtrace?
I just look for the sun, no sky description and use only direct
calculation (-ab 0) .
Jan
Dr.-Ing. Jan Wienold
Head of Team Passive Systems and Daylighting
Fraunhofer-Institut f?r Solare Energiesysteme
Thermal Systems and Buildings
Phone: +49(0)761 4588 5133 Fax:+49(0)761 4588 9133
http://www.ise.fraunhofer.de
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
Radiance-general@radiance-**online.org<[email protected]>
http://www.radiance-online.**org/mailman/listinfo/radiance-**general<http://www.radiance-online.org/mailman/listinfo/radiance-general>
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
URL: <http://www.radiance-online.org/pipermail/radiance-general/attachments/20120725/9ae71715/attachment-0001.html>
Message: 2
Date: Wed, 25 Jul 2012 09:44:51 -0700
Subject: Re: [Radiance-general] BSDF xml into Radiance
Content-Type: text/plain; charset=us-ascii
Hi Lars,
Andy probably is the right person to respond to this, but as he's on a vacation until the end of the month, I thought I'd offer a couple of comments (inline).
Date: July 25, 2012 1:18:42 AM PDT
Hi Andy, hi list-subscribers,
I just came across this recent message about the usability of the bsdf
material type with patch-based models of the sky including direct sun
and complex fenestration. To avoid misunderstandings, I will try a short
summary for others to comment on available options for annual
simulations with complex glazing:
1) classic radiance tools (rpict, rtrace), complemented by mkillum to
relax ambient setting.
Advantages: low noise, validated.
Disadvantages: very slow for annual simulations, no support when
non-planar specular reflective surfaces are involved.
More specifically, non-planar, specular reflectors run into trouble for insolation. Cloudy skies or sunless skies are no problem.
2) rtcontrib and patch-based model.
Advantages: faster for annual simulations.
Disadvantages: noise, nice images require high (slow) -ad and cannot be
optimized using mkillum, limitations about specular non-planar
reflectors apply.
The accuracy of non-planar, specular reflectors is actually better than #1, but the results are somewhat noisy. A new -c option to vwrays (coupled with the rtcontrib -c option) is a good way to reduce noise that is available in the latest HEAD. This is a better way to reduce noise than increasing -ad, and less costly.
3) rtcontrib and patch-based model, bsdf.
Advantages: support for non-planar reflectors, should be slightly faster
than 2) as the fenestration system does not have to be traced internally
- did anyone compare?
Disadvantages: still high -ad settings required leading to extended
rendering times and still no way to get mkillum in, tends to
underestimate direct sun (according Andy's message).
4) three-phase-method.
Advantages: very fast, can also be used with non-planar specular
reflectors as bsdf data is supported.
Disadvantages: requires quite a lot of set-up work, e.g. subdivisions to
reflect external obstructions. Patches visible in the results,
fenestration geometry is not visible.
Andy has proposed an improved annual simulation method, which we hope to work on next year, to remedy the direct solar sampling difficulties in the 3-phase method. It should also alleviate problems with external facade geometry and reduce the need to subdivide windows.
5) pmap.
Advantages: can be used with non-planar reflectors and multi-peak
transmission.
Disadvantages: unknown status (any news?), not integrated with rtcontrib
(contributions would need to be rendered manually).
So if I need a way to generate images with visible fenestration
geometry, the only reliable option would be 2), which requires very
hight settings for -ad and thud will still be rather time-consuming, if
noise is to be controlled.
On Tue, 2012-06-12 at 08:43 -0700, Andrew McNeil wrote:
Though I've found that the BSDF material doesn't work well for
daylight coefficient based annual simulations (I'm assuming dds.bash
is a dynamic daylight simulation script). Putting the solar radiance
into skypatches relies on probabilistic sampling to find patches
containing the sun, and if you don't have much direct transmission
from the direction of the sun, you aren't likely to find the sun. Not
finding the sun causes big errors.
Message: 3
Date: Wed, 25 Jul 2012 12:01:03 -0600
Subject: [Radiance-general] Genskyvec error revisited
Message-ID: <CC35907F.12D36%[email protected]>
Well, it looks like WindowsXP isn't the only problem. While genskyvec.pl
works fine with piped input from the command line on Windows7, when it's
called from within my Ruby script, I get the same error that Ryan Southall
reported with his Python script
(http://www.radiance-online.org/pipermail/radiance-general/2012-July/008758
.html).
Greg, I tried your suggestion again as well:
I can't test it for you, but I suspect the line:
} elsif (/\sskyfunc\s*$/) {
is the problem. Try removing the final '\s*' to make it:
  } elsif (/\sskyfunc$/) {
...but no luck.
Ryan, have you made any more progress with this issue? Anyone else?
Bueller?
Golden, CO 80401
303.275.4319
End of Radiance-general Digest, Vol 101, Issue 31
___________________________________________________________
This email has been scanned by MessageLabs' Email Security
System on behalf of the University of Brighton.
For more information see http://www.brighton.ac.uk/is/spam/
Dr Ryan Southall
Senior Research Fellow
School of Architecture & Design
Mithras House
Lewes Rd
Brighton
BN2 4AT
T: ++44 (0) 1273 642335
E: [email protected]
Thanks Ryan. That doesn't work on Ruby, unfortunately. Still looking
around the intertubes for a solution here.
Golden, CO 80401
303.275.4319
On 7/25/12 2:46 PM, "Ryan Southall" <[email protected]> wrote:
Hi.
I
the
own teeth).
Ryan
Today's Topics:
Message: 1
Message-ID:
Jan
point
your
On Tue, Jul 24, 2012 at 9:50 PM, Jan Wienold >> <[email protected]>wrote:
Hi Giulio, hi all,
cases
there
trial,
Thanks!
Jan
hi giulio,
Yes!
Otherwise
I
thanks!
jan
Jan,
G
rpict:
case
(=>this
same
Is just
solution for
this for rtrace?
Jan
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
Radiance-general@radiance-**online.org<Radiance-general@radiance-onli
ne.org>
Radiance-general@radiance-**online.org<Radiance-general@radiance-onlin
e.org>
In office:
Mo,Tue: 8:30-18:00
We,Thu: 8:30-16:00
Fr: 8:30-15:30
Radiance-general@radiance-**online.org<Radiance-general@radiance-online.
URL:
Message: 2
Hi Lars,
comments (inline).
short
reflectors apply.
faster
internally
to
to
5) pmap.
transmission.
rtcontrib
Message: 3
Southall
58
.html).
...but no luck.
Bueller?
Golden, CO 80401
303.275.4319
Dr Ryan Southall
Mithras House
Lewes Rd
Brighton
BN2 4AT
