I’m affraid my first attemp to post this message hasn’t been successfull, so I try it once more. Please don’t take this mail into account, it the first one is alredy posted:
After downloading the dynamic binaries for Linux and installing the radiance’
library I’ve tried to execute the rad-command from the tuturial (rad -o x11
daf.rif) as well as just the rview-command with other oct-files, but
unfortunately the -vp option could not be executed and I got the following
VIM - Vi IMproved 6.2 (2003 Jun 1, compiled Sep 26 2003 16:12:37)
Unknown option: "-vp"
there was a discussion some time ago about the problem that the filename "rview" is used by vi (a text editor) as well as radiance. AFAIK in newer releases of radiance, rview was renamed. The rview that reported the unknown option to you is from vi(m), not from radiance. You could take a look at what the vi-rview is, maybe you don't need it and can rename it into rview.vi. "which rview" should point you to the file that was executed when you wanted to start rview, it might be /usr/bin/rview. You can also get a cvs-snapshot of the current radiance-development-tree from www.radiance-online.org, if you want to compile it on your own (or maybe someone offers binaries of the cvs-radiance?).
"quicker than the eye could flick..." ;-))
cheers,
giulio
Sent: 19 May 2004 13:02
Subject: Re: [Radiance-general] problem with options of 'rview'
cvs-radiance?).
No one mentioned the simplest solution, which I suppose is obvious, of changing your PATH environment variable in your shell so that the Radiance bin directory (/usr/local/bin by default) preceeds the directory containing vim (/usr/bin usually). This will fix the problem without having to rename or reinstall anything. Renaming Radiance's "rview" to "rvu" will break the concurrent release of "rad," which still calls "rview" to start an interactive rendering.
I'm affraid my first attemp to post this message hasn't been successfull, so I try it once more. Please don't take this mail into account, it the first one is alredy posted:
After downloading the dynamic binaries for Linux and installing the radiance'
library I've tried to execute the rad-command from the tuturial (rad -o x11
error:
