problem with import Radiance resutlt to ECOTECT
I built a model in ECOTECT and exported to RADIANCE to calculate daylight
performance. However, when i finished and i imported the result file with
.OK extension to ECOTECT. I can not. ECOTECT said "invalid file format"
Furthermore, it is the same thing with DAYSIM, when i imported DA file. Can
anyone tell me what is the problem?
Best Regards!
Vincent
Vincent. Are you using a grid or point attributes on surfaces? .ok
and .da files will only work on a grid. Point attributes needs a bit
of a workaround but can be done.
daylight performance. However, when i finished and i imported the
result file with .OK extension to ECOTECT. I can not. ECOTECT said
"invalid file format" Furthermore, it is the same thing with DAYSIM,
when i imported DA file. Can anyone tell me what is the problem?
Best Regards!
Vincent
