Hi, guys,
I don't know if you can kindly advise me on a Python related problem, or
suggest a source for help:
1. the following gencumulativesky command runs OK in the terminal of Mac OS
using London's weather file:
*GenCumulativeSky +s1 -a 51.15 -o 0.18 -m -0.0 -h 0 -E -time 0 24
-date 1 1 12 31 ./London.epw > ./gcs_London.cal*
... with two lines of error message:
*There were 4586 sun up hours in this climate fileTotal Ibh/Lbh: 0.000000*
2. But I can't get it working at all by running a Python script with the
following contents:
*import oscmd = "GenCumulativeSky +s1 -a 51.15 -o 0.18 -m -0.0 -h 0
-E -time 0 24 -date 1 1 12 31 ./London.epw >
./gcs_London.cal"os.system(cmd)*
There is no error message in the Python IDLE, but the .cal file generated
is zero ...
Moreover, I got a lot more error messages when running the gencumulativesky
program directly in the terminal of Mac OS X using Singapore's weather file:
Command:
*GenCumulativeSky +s1 -a 1.37 -o -103.98 -m -120.0 -h 0 -E -time 0
24 -date 1 1 12 31 ./SGP_Singapore.486980_IWEC.epw > ./gcs_SG.cal*
Errors:
*Error! Solar altitude < 6 degrees and Idh > 10 W/m^2 on day 1!
Attempting to continue!......Error! Solar altitude < 6 degrees and Idh >
10 W/m^2 on day 365! Attempting to continue!There were 4354 sun up hours
Thanks for your help!
