Problem installing radiance onto Mac OSX-Leopard: running trad
It's been a while since I last installed Radiance - so memory may be hazy - but I believe you may need to create the /tmp directory and set permissions also.
-John
PS. X11 on Leopard is a little clunky. If you start it from an X11 icon in the dock, you may end up with two X11 icons. Which doesn't hurt, but it is annoying nonetheless. The workaround I stumbled upon was to drag the X11 application icon to the lower-left pane of the Finder (i.e. making a shortcut X11 icon), and then starting X11 from that.
Dr. John Mardaljevic
Senior Research Fellow
De Montfort University
The Gateway
Leicester
LE1 9BH, UK
+44 (0) 116 257 7972
+44 (0) 116 257 7981 (fax)
jm@dmu.ac.uk
http://www.iesd.dmu.ac.uk/~jm
