problem generation dmx matrix
Dear expert,
A brief introduction to the project:
I'm appling 3 phase method on a facede that is composed of a big cfs on the
bottom of which there are several openings (glass doorway) that are the
access to the internal area.
Therefore, I have decided to separet the facede in two groups (CFS &
GLASS_DOOR) since the BSDFs are different (I hope that it is the right way
to proceed).
But when I have generated the dmx matrix for both groups of windows, that
have the same orientation (-vd -0.98 -0.17 0), a warning message have
appeared only for the GLASS_DOOR group:
*view direction does not correspond to any surfaces.*
Controls:
1. checked geometry with objline and rvu (for the glow material) and all
seems work well.
2. checked oconv that contain material, scene without the window ,
skywhtie.
3. checked the command for the glass_door (that is the same of the
functioning one save for the geometry):
genklemsamp -c 1000 - vd 0.98 -0.17 0 materials.rad glass_door.rad |
rcontrib -n 4 -c 1000 -e MF:1 -f reinhart.cal -b rbin - bn Nrbins -m
sky_glow - faf temp/model_dmx.oct > data/glass_door.dmx
I don't know where find the solution of the the problem. Any advice?
Thanks in advance,
Giuseppe
Hi Giuseppe,
Thanks for sending your input files. There's nothing you are really doing wrong, but you've run up against a limitation in genklemsamp to find surfaces that are widely separated. Your windows are nice and close-together, so they don't pose a problem, but your doors are small relative to the space between them, such that the sampling process, which is based on the bounding cube, cannot locate them even with 1000 initial samples (your -c setting). The solution is to either run genklemsamp on each door individually, or to increase the sampling rate to -c 10000, which works in your case.
Subject: [Radiance-general] problem generation dmx matrix
Date: July 13, 2014 4:39:02 AM PDT
Dear expert,
I'm appling 3 phase method on a facede that is composed of a big cfs on the bottom of which there are several openings (glass doorway) that are the access to the internal area.
Therefore, I have decided to separet the facede in two groups (CFS & GLASS_DOOR) since the BSDFs are different (I hope that it is the right way to proceed).
But when I have generated the dmx matrix for both groups of windows, that have the same orientation (-vd -0.98 -0.17 0), a warning message have appeared only for the GLASS_DOOR group:
Controls:
1. checked geometry with objline and rvu (for the glow material) and all seems work well.
2. checked oconv that contain material, scene without the window , skywhtie.
3. checked the command for the glass_door (that is the same of the functioning one save for the geometry):
genklemsamp -c 1000 - vd 0.98 -0.17 0 materials.rad glass_door.rad | rcontrib -n 4 -c 1000 -e MF:1 -f reinhart.cal -b rbin - bn Nrbins -m sky_glow - faf temp/model_dmx.oct > data/glass_door.dmx
Thanks in advance,
Giuseppe
Greg,
the dmx works well now (I have tried only the increasing of rays number for
now), so thanks again.
Giuseppe.
2014-07-15 18:59 GMT+02:00 Greg Ward <[email protected]>:
Hi Giuseppe,
works in your case.
*Subject: *[Radiance-general] problem generation dmx matrix
*Date: *July 13, 2014 4:39:02 AM PDT
Dear expert,
to proceed).
Controls:
seems work well.
skywhtie.
Thanks in advance,
Giuseppe
*Giuseppe De Michele*
By the way, I am working on a more general tool that will replace genklemsamp and run rcontrib for you, which should eliminate this issue. Hoping to have it done by the end of next month, maybe sooner.
Subject: Re: [Radiance-general] problem generation dmx matrix
Date: July 18, 2014 12:14:04 AM PDT
Greg,
the dmx works well now (I have tried only the increasing of rays number for now), so thanks again.
Giuseppe.
Hi Giuseppe,
Dear expert,
Controls:
Thanks in advance,
Giuseppe
Giuseppe De Michele
